Konica Minolta C280 Not Printing
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C280 Not Printing
    Konica Minolta C280 Doesn't Print. Data light flashes and disappears.
    Changed the Ethernet cable.
    Can send scan to email etc. Copy can be done as well.
    Please advise
    Thanks and Regards,
    mearmi
  • BR549
    • 111
    Re: Konica Minolta C280 Not Printing
    Is account tracking enabled on this machine? I believe that would be the symptom if account tracking is being used and you used a invalid account code. Or no code is entered in the driver. Or if they have limits, that account may have reached their limit.
    • paulrid
      • Nov 2011
      • 206
      Agree with BR549 also check print history and see what it says.
        • 23009
        The simplest way to find out if you can print is to connect you laptop via crossover cable and install a driver. For testing purposes I've found that my Lexmark universal driver will send a valid print job to nearly any MFP. All I do is determine what the printers IP is, set my laptop to an IP (last octet +1), and add a port to my Lexie driver at the printer's IP. Within 5 minutes you should know if the MFP can or cannot print. =^..^=
        • mearmi
          • Oct 2010
          • 350
          Thanks for your reply. No account tracking is enabled.
          Regards,
          • AjitN
            • Mar 2009
            • 287
            Simple things first, if data light flashes & job gets deleted, try printing internal demo page.
            If it prints well then your print processor is good.
            if not you need to load firmware, I face this problem with C360.
            Hope this helps
            • MFPTech
              • 486
              Please advise
              Thanks and Regards,
              mearmi
              it looks like raw data is going to the machine? check job que from page scope. Conflict IP on the network? unplug the network cable and print directly from your laptop. crossover cable no longer needed, straight through cable is fine
              Hope this helps
              Sent from my SGH-I337M using Tapatalk
              • musthafavi
                • Aug 2017
                • 76
                Me to also having the same problem with konica Minolta C360. Doesn't Print. Data light flashes
                I can print demo page
                Account tracking is OFF
                Please help me how to solve this issue
                • copier tech
                  • 8174
                  Are they any messages on the screen? transfer belt etc maybe over life
                  • musthafavi
                    • Aug 2017
                    • 76
                    There was a message to change transfer belt unit, so i replaced with new one, after changing also warning message was popup, so I reset the value from service mod
                    Please see the attached consumable details
                    • copier tech
                      • 8174
                      All consumables look fine.
                      If account track etc is definitely turned off try a clear all data in service mode.
                      • musthafavi
                        • Aug 2017
                        • 76
                        Thanks for your support,
                        Could you please tell me where this Clear all data option located in service mode
                        • copier tech
                          • 8174
                          From memory system2>Initilisation>data clear
                          • MFPTech
                            • 486
                            Reset the machine in SM - clesr all, setup network and fax, install movie data and MFPTech is your uncle
                            Sent from my SM-G900W8 using Tapatalk
                            • copier tech
                              • 8174
                              Where about in Surrey you from dude?
