BizHub C224 FK-511 fax kit
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Will the FK-511 work in both the C224 & C224 "E"? I need to buy a few and looking on Ebay there was conflicting info. Some listings had the FK-511 will work in both versions, others had it that they are not interchangeable.
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: BizHub C224 FK-511 fax kit
    same fax both models. not a problem.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      After I posted I investigated a little more looking at both brochures and serv manuals and they list fax kits for both as FK-511, however looking at dealer pricing there are 2 different part #'s for FK-511, C224 A4MF011, C224e A4MF012. Did you try swapping them before?
      • Synthohol
        • 5849
        the 11 and 12 are likely revision numbers, never had an issue especially when we would swap faxes from old model to new.(e)
        • emujo
          • Jun 2009
          • 3009
          The fax works in both machines, but, the firmware is different. You should be ready to re-load if you get an error. Emujo
