BizHub 222: printing (won't print to PC)
  • RandyW
    • Jan 2013
    • 213
    1 of our accounts acquired a BizHub 222 from another 1 of their locations.
    Pretty sure they were trying to print on a network with Windows 7 x 64 bit.
    We entered an IP address and were able to ping it but never could print to it.
    Ricoh has a thing they call the Web Image Monitor were you put the IP address in a web browser. We tried that and nothing
    came up. There was a Universal Print driver we tried to use.
    Is it possible the firmware needs to be udated? Or it doesn't have drivers that will work.
    thanks.
  • guitar9199
    • Sep 2016
    • 1100
    Re: BizHub 222: printing (won't print to PC)
    As a test, try connecting a laptop with a USB cable and see if the unit will print at all. If it does, it's most likely network related....if not, it's the machine.
    ...at least that's where I'D start.... YMMV
    • Woxner
      • Jul 2011
      • 850
      reset the network to auto and let it pick up everything. make sure authentication is not on. use the pcl driver. universal sucks. also try a crossover and a laptop. usb printing is different. if network port is bad usb will still work. you may need to update firmware for browser problem. what os are you using. also use chrome.
      • Synthohol
        Certified Konica Expert
        • 5846
        if you can print a configuration page the controller is working (usually)
        does it?
