Konica minolta bizhub c224e error FA14
  • Azharuddin
    • Jun 2016
    • 33
    [Error Code] Konica minolta bizhub c224e error FA14
    Hi all ,
    I had a call today that a c224e was not printing issue.I went there to see If I could able to check the network but the machine was showed up the error FA14. I restarted the machine and checked the error history it was only FA14 . Tried to transfer the data SSD to HDD at 50% it stopped working and I restarted it it shows that CE-301. Then I disabled the HDD it's works. But there is no networking . When I plugged in the network cable it got hangs.
    Whether I have to replace the HDD or anything else. Thanks in advance.
    Sent from my XT1562 using Tapatalk
  • Woxner
    • Jul 2011
    • 850
    Re: Konica minolta bizhub c224e error FA14
    update the firmware to k-6 also make sure there is no corrupt jobs in the q or duplicate ip. ping ip with cable unpluged
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      Think there is a bulletin about that code. Wox is usually spot on with his info, but if it doesn't work I'll see if I can find the tech bulletin.
      • Azharuddin
        • Jun 2016
        • 33
        Thanx Wox,
        There is no Duplicate ip, but when I connect the network cable on machine, it became slow.
        I tried to reset the network settings even though same.
        Copy man can u attach the bulletins it may helpful .\
        Thanx again
        • Reed
          • Feb 2011
          • 258
          There are actually a few firmware updates since K6. I just updated one last night to G20-M0. The bulletin lists the C-E301 error as one of the fixes.
          • Azharuddin
            • Jun 2016
            • 33
            Can anyone share the K6 firmware file.
            • Azharuddin
              • Jun 2016
              • 33
              Tnx to all,
              Replaced HDD it's ready.
