Minolta C364 counters?
Re: Minolta C364 counters?
why would you want to reset the counters to zero.....Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away... -
Selling w/o any leftover data is quite a bit different that selling with the counters reset to zero. A data wipe is a just good practice as it can reduce the chance of sensitive or secure data accidently getting into the hands of someone that shouldn't have that info..HIPPA for one example. Resetting the counters is just plain illegal. Which one are you really referring to? EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
The medication helps though...Comment
Does that work on the 224 range with the SSD?
I know it works on the 220 range. But why??
You use a nvram with a lower count and the recipient will accept the value with that method.
Still no integrity...
Engine life can be exceeded on most KM machines.
I would not be happy to find out that my second hand car's odo was turned back.WhateverComment
A machine with 700k on it can be just as reliable as one with 100k if its been maintained and modified properly. Meters mean jack shit within reason and as long as it is going into the correct environment for its point in life.
I'd rather a machine with 700K thats been maintained properly than one at 250K that some tight dealer has reset the lives of everything on. (Just had to refurbish just such a POS last week)Comment
The same can be said about a vehicle, it may be well maintained and around 200K, but if you replace the odometer and let me assume the car only has 60K miles on it I think we will be seeing one another in court. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
