C6500 lines cyan and magenta.
  • Synthohol
    Certified Konica Expert
    • 5849
    #31
    Re: C6500 lines cyan and magenta.
    its off by 1, irrelevant.
    • khadimetareqat
      • Mar 2017
      • 35
      #32
      Originally posted by synthohol
      does the electronic meter match the mechanical one or was something done to the nvram that borked the meters and started this whole thing?
      my machine have difference of one degit in their counters
      kindly help me how to set
      • Synthohol
        • 5849
        #33
        nope, leave it alone it's fine. they are all like that.
        • khadimetareqat
          • Mar 2017
          • 35
          #34
          Originally posted by Synthohol
          this needs to be followed EXACTLY
          Problem
          Security lines on copies
          Solution
          CAUSE: Initial settings did not take when programmed.
          SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
          1. Sub-power ON Utility/Counter Machine Admin settings System settings Date and time setting (Enter year/month/day/time) OK Exit Power OFF sub-power switch.
          2. Enter Service Mode System settings Setup date input (Enter year/month/day) OK.
          CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
          3. In the Service Mode System settings Telephone setting (Enter 16-digit number) OK. Repeat for the fax number. Set to all 9s if there is no fax number.
          4. In the Service Mode System settings M/C serial number setting touch ADF (Enter ADF serial number) OK Power OFF sub-switch.
          5. Power ON sub-switch and run copies with no security lines.
          sir manual showing to adjust adf adjustment.
          but when i adjust auto then screen shows unable
          test chart i downloaded from your link but that also no working.
          kindly help me
          • marexim2000
            • May 2017
            • 16
            #35
            Problem
            Solution
            I have a Konica C258 and I have exact some problem but only in copy mode if I print from desktop is OK. This procedure is the some for all equipment? Can I use it on my C258? I don't have a install procedure and is possible to missing some.
            • Synthohol
              • 5849
              #36
              Most techs leave the set-up guide in the document holder with the machine if it's not there let me know and I could send you a link when I get home tonight
              • khadimetareqat
                • Mar 2017
                • 35
                #37
                Hi dear kindly send me link
                • marexim2000
                  • May 2017
                  • 16
                  #38
                  I don't have installation procedures for my bizhub c258, if you can give me a link for its, please.
                  thousands of thanks
                  • Synthohol
                    • 5849
                    #39
                    here.
                    • marexim2000
                      • May 2017
                      • 16
                      #40
                      here.
                      Thank you. It is OK, now.
