I'm not very good at imagining image quality issues. Maybe you could include visual aids, like a scanned sample? =^..^=
One print in sequence, the lines alternate between magenta and cyan...
I can't see it very well. Do you have a larger image? =^..^=
what i dont understand is his post with the NVRAM set mode, are these lines cause by playing with settings he has no business tinkering with?
was it fine before you messed around?
these lines means that when you first initialize your machine out of the box, and miss one or few steps of initialization, like stabilization and gadation. When you clear NVRAM, then you have to do initialization again, step by step, to avoid the lines of shame (cyan and magenta). So my advice is to do initialization step by step and it should work fine.
Good Morning. Thanks for the tip. They are exactly the lines of security.
The client is new and I do not know what was done before, I just came across the problem.
Is there any way to reset the NVRAM of C6500?
I will take the installation step by step again and post the result here.
