just picked up a 7255
  • Printer1545
    • Mar 2015
    • 5
    Stumbled on a Bizhub 7255 with a Pi-110 I picked up for less than 100 Bucks. Low Meter (1.5 m), had drum etc. replaced in 05. I have no Experience with a High production Machine like that but bought it to explore it what it can do and how it works.
    Looking for a service manual and can this be hooked up to OSX?
    Ludwig
  • rrrohan
    • Sep 2011
    • 1977
    Re: just picked up a 7255
    this looks like a bizhub 600. i dont recall seeing that model in my region so might be the equivilent
    those have 10.12 PCL drivers so the 7255 probably will too
    • Synthohol
      Certified Konica Expert
      • 5814
      MAC 10.4 is the last Mac OS supported
      Self-Help Product Support | Konica Minolta Business Solutions, U.S.A., Inc.
      type 7255 in the box and see what drivers are available.
      • mx6turbo89
        • Oct 2013
        • 154
        Ludwig
        Check your PM
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          You should of charged them $100 to take it away not the other way around.
          Here that machine is scrap metal value and has not been supported for years, not sure about over there.
          • Printer1545
            • Mar 2015
            • 5
            where is here?
            Used they go for a couple grand here, there seems to be still a number around of them, I;m in Sunny California
            • Albonline
              • Sep 2008
              • 1147
              Ludwig
              put it back down!
              • Printer1545
                • Mar 2015
                • 5
                yep, they're heavy
                • Albonline
                  • Sep 2008
                  • 1147
                  where is here?
                  Here they go to the junkyard, 3 generations back, and every one of the generations were toner/developer spewing pigs! good luck getting parts, the 2 series is long into obsolescence.
                  BTW, to print it would have to have the addon ip unit. 511 if memory serves.
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    I was stripping parts to throw away old machines in the warehouse today and found one, with print controller, that looks new and has 85,000 total meter. Looks like a nice rental or loaner. I just couldn't throw it away. It looks really great.
                    • Printer1545
                      • Mar 2015
                      • 5
                      To me they look really solid build, Layout makes sense, easy to access compared to the more modern ones.
                      • Synthohol
                        • 5814
                        its still a 15 year old headache. id use it for a loaner but never for sale.
                        12/2002 it was officially discontinued and no parts or supplies are made for it anymore.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4666
                          Light fuse, get away!
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4666
                            Bottom line, you think K/M would of learned that recycling waste toner just don't work on high volume machines! Paper dust contaminates the developer. Kept this same foot print for over 10 yrs. From Di-750 all the way until a few years ago with the Bizhub 601/751. All that time you think they would've changed the design. Of course not...
                            Actually I just added this to my all time top 10 list for worse copiers ever made. If you can't get a 75 ppm "production model" machine to run PM to PM when the cycle is only 250k then that machine is a piece of crap! I've had the "pleasure" of servicing this design from the Di-750 up to the Biz 751 and never met one I liked. Including brand new out of the box.
                            Had only one that worked OK for medium volume office but only after adding an LCC. The paper feed system is horrible on these.
