Konica Minolta Bizhub c454e
  • Valintine
    • Jan 2012
    • 147
    Hello
    I have been working mainly on Toshiba's for almost 30 years now and the boss brought in a Konica Minolta Bizhub c454e. It came in with a message referring to the hard drive. I was able to formatt the hdd and the machine comes to ready. When I try and copy the job shows up in the job list with the message "stop printing" and if I leave it there it eventually shows up in the log as "error deletion."
    Any thoughts or help would be greatly appreciated.
    • 23010
    Re: Konica Minolta Bizhub c454e
    I get the feeling that you haven't glanced at the manual.
    Have you given any thought to re-loading the firmware and movie data? It's covered in the manual. =^..^=
    • Valintine
      • Jan 2012
      • 147
      Thank you for the reply. I have looked at a manual and am not sure if it a complete one or a condensed one. It does not seem to be complete. I have tried loading the firmware but must be missing something simple.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        go in service mode and do both logical and physical then load movie data. No firmware on HDD so that may not be needed.
        • Woxner
          • Jul 2011
          • 852
          also check the t belt and fuser counters if they exspire the machine will not make copies it locks you out at some point.
          • allan
            RTFM!!
            • 5462
            Go in to service mode and check the error history.
            What codes do you get there if any?
            Whatever
            • emujo
              • Jun 2009
              • 3009
              "Stop printing" has always been associated with an IU going past its life span. Someone probably did a factory reset and put the life stop mode back to stop. Search this site for PPLM and you will get all the info for softswitch settings to alleviate this issue, w/o PPLM installed, the MFP will stop printing at (I believe) 150% past life. The other items (toner, X-fer belt, fuser) all show up on the LCD screen with a message to replace "XXX" and you can't get to copy mode until then. Emujo
              • Synthohol
                Certified Konica Expert
                • 5857
                Is account track in use? The will kill jobs too.
