C452 strange lines
  • barber782
    • Aug 2011
    • 289
    C452 strange lines
    Hi everyone,
    Today I got a biz hub c452 which prints and scans vertical colored lines, not consistent either. Some are dashed lines. See sample.
    301 Moved Permanently
    Sent from my GT-I9195 using Tapatalk
  • Max
    • Oct 2011
    • 581
    Re: C452 strange lines
    I would say its down to MFP or a printer controller board. I would personalty try MFP board 1st.
    • service_man
      • Jul 2012
      • 59
      Did you try stabilization image?
      Check Transfer Belt, maybe is gear who turn Image Transfer Belt.
      Regards
      • barber782
        • Aug 2011
        • 289
        Done stabilisation and updated firmware.
        • Albonline
          • Sep 2008
          • 1156
          Originally posted by barber782
          Hi everyone,
          thats ram /memory artifacting. looks like its in the working memory area . try removing and cleaning and reinstalling ram, also try replacing it. there is also ram built onto the mfp board.
          good luck
          • Synthohol
            Certified Konica Expert
            • 5961
            had a 423 do the same, was the mfp board in our case.
            • barber782
              • Aug 2011
              • 289
              Yes new mfp board fixed the problem. Thanks peeps.
