Help C308
  • Shinigami
    • Mar 2017
    • 44
    Help C308
    Hello peoples!!
    If someone can help me in that case please!
    I want ask if there is some backup for the scan and box configuration ! Because in some case whene the HDD is formatted ! I will be forced to redo the configuration!
    Thank tou all
  • service_man
    • Jul 2012
    • 59
    Re: Help C308
    You can export on the computer users, who scanning, and adress book from web browser with administrator login, but configuration of the scan etc. \\computer-PC\scan, i think that you cant.
    My costumers, not ask me that. Because, when I change the HDD, I must install movie file, and easy job is to configure scan.
    But I have from every costumer copy of adress book.
    And only Import adress book, and everything is working fine.
    Regards
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      Re: Help C308
      http://www.copytechnet.com/forums/ko...tml?highlight=
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • Synthohol
        Certified Konica Expert
        • 5892
        Re: Help C308
        set bit sw 72 to hex 04 and hit fix.
        no need to reboot, go into admin, external backup and copy all to a small flash drive.
        • TheBlueOrleans
          • Aug 2012
          • 232
          Re: Help C308
          SW 72, hex 04 works for "cloning" machines, but I just found out today that I can't do that in the case of a C-D010 code. Couldn't access admin mode to export anything, so thankfully all they lost was one fax One Touch. Easily remedied, as long as someone knows the bloody fax number...
          We had mass deployments a couple years back (when I was just the Shop Tech, doing setups all day), with deployment guides out the wazoo, and it was MUCH easier once we figured out the SW 72 hex 04 clone trick. It copied almost every one of the settings from the deployment guide over to each machine, once we got one configured. Lovely little trick.
          Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
          • Synthohol
            • 5892
            Re: Help C308
            isnt that code about the HDD and the need to the special upgrade to sata ver 4?
            i have recovery FW if you ever need.
            • rrrohan
              • Sep 2011
              • 1977
              Re: Help C308
              Im surprised a useful feature like external memory backup is a hidden feature
              • kingarthur
                • 1385
                Re: Help C308
                I've discovered & been advised by KM, thay when you use s/s 72 to back up to a USB, anything on the HDD isn't saved, I've also discovered that not all network settings are transferred either...
                • emujo2
                  • Mar 2017
                  • 1579
                  Re: Help C308
                  The only way to back up a KM HDD (to my knowledge) is the HDD backup plugin for PSDA. This takes many hours to run, and will backup everything in the user boxes. Emujo
