Replacement MFP
  • antone
    • Oct 2014
    • 344
    Replacement MFP
    Locked up invalid external error
    Sent from my SM-N920V using Tapatalk
    • 23010
    Re: Replacement MFP
    It might help to know what hypothetical model of MFP this is. =^..^=
    • Woxner
      • Jul 2011
      • 853
      Re: Replacement MFP
      what machine. are you saying you replaced a mfp board? and was it from another machine. did you try and do firmware and got this. little more info needed. i dont do mind reads on fridays
      • allan
        RTFM!!
        • 5462
        Re: Replacement MFP
        Feels like a WTF thread. Why not just do that...
        It break me up.
        Whatever
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Re: Replacement MFP
          • antone
            • Oct 2014
            • 344
            Re: Replacement MFP
            Biz hub 654e..tryed 3 MFP boards...firmware updated to latest version....than hangs up and locked up..right there
            • Woxner
              • Jul 2011
              • 853
              Re: Replacement MFP
              if you used a board from a different machine then yeah you have a problem. you might use a reset tool to get this to boot up. your not supposed to swap pwb's. they back each other up and if the info is not the same it wont boot
                • 23010
                Re: Replacement MFP
                Have you tried initializing the MFP board? That would be required anyway, if perchance your boards were used. =^..^=
                • antone
                  • Oct 2014
                  • 344
                  Re: Replacement MFP
                  Sounds good...how do you initialize the MFP
                  • lahorebooks.lb
                    Re: Replacement MFP
                    Any one help me 5875
                    R2R3 stabling xerox
                    Sent from my QMobile Z8 using Tapatalk
                      • 23010
                      Re: Replacement MFP
                      R2R3 stabling xerox
                      Perhaps you might like to start a new thread in the Xerox forum ... where the Xerox techs might read it, rather than hijacking Antone's thread in the Konica Minolta forum?
