Konica Minolta C364 Scanner Adjustment Centering - Color Chart
  • mearmi
    • Oct 2010
    • 350
    Getting problem with Side Edge Margins in Konica C364. From all the paper trays it is same.
    For ADF we adjusted in Service Mode by going to Machine-Scan Area and Side Edge and it is fine.
    But from the platen glass still getting less margin on the side.
    Do we need to have Konica Minolta Color Chart. If someone can send us.
    Thanks and Regards,
  • Max
    • Oct 2011
    • 561
    Re: Konica Minolta C364 Scanner Adjustment Centering - Color Chart
    Check your trays. Make sure the side to side fences are centralized and not off set to one side. Once you get that in the right place for the off the glass copy then adjust the DF.
    • mearmi
      • Oct 2010
      • 350
      Fences are centralized.
      Print is fine but copy from Platen glass is still same. Please find the attachment. Thanks
      SWHC36417042916090.pdf
      • Synthohol
        Certified Konica Expert
        • 5849
        is the long or short edge the lead edge?
          • 23009
          Excuse me for saying so, but isn't you're image reduced 8% along the short edge and 3% along the long edge, if those arrows were touching the edge of an A4 original? Don't you thing you should address that first, before trying to move the image around? =^..^=
          • mearmi
            • Oct 2010
            • 350
            Leading Edge is fine.
            It is Long Edge (Landscape).
            • Synthohol
              • 5849
              long edge is portrait.
              please clarify.
              • allan
                RTFM!!
                • 5462
                You have to do print area then do scan area. Do all the adjustments including the magnification adjustment.
                You don't need a chart.
                Whatever
                • mearmi
                  • Oct 2010
                  • 350
                  Thanks a lot
                  • Barry97
                    • Jun 2022
                    • 23
                    [ATTACH]36509[/ATTACH]
                    This one is new to me. where do you get that print out.
