Can't make web connection with bizhub 600
  • Zahid khan
    • May 2016
    • 72
    I have connected bizhub 600 directly with pic via Ethernet cable.i put the IP address in browser but nothing happens.to find the ip of bizhub I go to utility...administrator setting....network settings...
    tcp/ip setting .....
  • rudysemira
    • Oct 2016
    • 108
    Re: Can't make web connection with bizhub 600
    You mean directly to PC from your machine. If you set static ip address to your copier then from pc, you need manually assign too., Go to local area connection then tcp/IPv4 set assign ip address manually if you are giving to the machine 192.168.100.10 then from pc should be 192.168.100.11.........try to ping.. Good luck
    • Zahid khan
      • May 2016
      • 72
      I tried that but no luck
      • rudysemira
        • Oct 2016
        • 108
        CAN YOU POST SCREENSHOT
        • Zahid khan
          • May 2016
          • 72
          here are the screen shots
            • 23010
            Does it have the IC-202 Print Controller option? Base models cannot print. =^..^=
              • 15011
              Pretty sure the network screen would not be available on the display if the print controller was not installed.
              • Zahid khan
                • May 2016
                • 72
                I checked printer controller is not installed .can I scan to pc without printer controller
                  • 23010
                  Sorry, not true.
                  Nope. You need the IC-202 for scanning. Maybe you could do some of this research yourself, like Google? That's how I found out: http://www.copycom.eu/storage/app/me.../km-bh-750.pdf
                  • Synthohol
                    Certified Konica Expert
                    • 5906
                    IIRC you can update the firmware with the standard network port but nothing else.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4785
                      I thought the Biz 600/750 came with scanning but not printing? Or maybe it is the Biz 601/751 with scanning included and not needing print controller chip?
