Bizhub 600
  • Syed Naseem
    • Jan 2017
    • 29
    Bizhub 600
    Hello everyone..
    I have a bizhub 600 which show paper jamming J-3206.
    I will check completely but nothing paper anywhere.
    I replace complete ADU unit but still issue same.
    Have any friend idea how to resolve this issue.
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Bizhub 600
    its the exit sensor turning on during idle.
    not an ADU issue.
    • Syed Naseem
      • Jan 2017
      • 29
      Re: Bizhub 600
      not an ADU issue.
      I replace the exit sensor too..
      But problem still same.
      • Woxner
        • Jul 2011
        • 851
        Re: Bizhub 600
        take the left end cover off and remove the exit assembly. paper maybe stuck in there and the mylar could be bent . could also be adu pwb
        • Synthohol
          • 5849
          Re: Bizhub 600
          yeah, give that actuator an extra spring wrap if you can.
          sensor check 24-2 is the exit sensor PS37
          1. "Service Mode screen"
          Press the [State Confirmation] key.
          2. "State Confirmation screen"
          Press the [Sensor Check] key.
          3. "Sensor Check screen"
          Enter the check code and the multi code with the sheet number setting button.
          The condition (H/L) of the sensor appears.
          4. When conducting other sensor checks, repeat Step 3.
          5. Press the [OK] key.
          State Confirmation screen appears.
          • Syed Naseem
            • Jan 2017
            • 29
            Re: Bizhub 600
            I replace exit unit too...
            Still same situation......
            • Synthohol
              • 5849
              Re: Bizhub 600
              i'd try to reflash firmware then
              trace the exit wire back to the prcb and check for a pinched or chafed wire along the way.
