Check one of the snapshot
  • tivzualuke
    • Dec 2016
    • 17
    Sent from my Infinix HOT 4 using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5876
    Re: Check one of the snapshot
    looks like you need black toner?
      • 23010
      I think that I'd start by washing off the operation panel. It looks like you'd stick to it, if you were to touch it.
      Maybe it would be pertinent to know what model bizhub this is. =^..^=
      • tivzualuke
        • Dec 2016
        • 17
        No full the cartilage
        • tivzualuke
          • Dec 2016
          • 17
          I mean toner the cartilage
          • tivzualuke
            • Dec 2016
            • 17
            Toner full the cartilage
            • Synthohol
              • 5876
              well the chip on the bottle is not being read, either bad chip or check the 3 gold terminals on the machine that make the contact with the chip.
              • Brett GS
                • Jun 2013
                • 154
                Check toner conracts and make sure they not bent.
                • marvin_PL
                  • Jun 2012
                  • 24
                  There's no chip.it's bizhub c220 series
                  • habik
                    • 2013
                    Try to manually add toner in service mode.
                    or
                    Take the exit tray cover off and have a look if the bottle is spinning. remove the bottle and have a look if there is any toner inside the hopper. If it is then switch the machine off and pull the drum and dev unit out and check if the dev unit is getting toner inside. If it does then check if the door switch is operating OK if there is no tonner in hopper or dev then remove the tonner hopper and clean everything you see. Sensors, vacuume the hoppers and then check for proper operation of actuators and agitators and shutters manually.
                    Check in history if there is any C-Codes.
                    Firmwares HERE
