C754 D012 code
  • nathicana
    • Aug 2008
    • 329
    C754 D012 code
    This C754 is going back to the lease company. To protect customer's data I ran HDD Overwrite All.
    Then the machine said "format hdd or reset encryption code" followed by D012 about 10 seconds later. I formatted hdd.
    Now I am getting a D102 code about 10 seconds after startup.
    I am not knowledgeable about these machines, we are a Kyocera dealer.
    Any help would be great.
  • Woxner
    • Jul 2011
    • 841
    Re: C754 D012 code
    well you did the wrong format. that overwrite referes to when the hdd is in use. if it has bizhub secure you need the password to rerformat. but try to do it in service mode. you might get away with it.
    • nathicana
      • Aug 2008
      • 329
      Re: C754 D012 code
      Thanks for the reply
      How do I enter service mode and format?
      I tried utility/ counter list/ stop 0 0 stop 0 1 but could not find counter list.
      Also concerned error will come up and lock me out, guess I have to do it fast.
      • nathicana
        • Aug 2008
        • 329
        Re: C754 D012 code
        I got into service mode. Should I do physical format or logical format?
        • Woxner
          • Jul 2011
          • 841
          Re: C754 D012 code
          logical takes ten mionutes or so phy will take hr upon hours. it will ask for movie data upon reboot
          • nathicana
            • Aug 2008
            • 329
            Re: C754 D012 code
            I did both physical and logical format. No difference.
            What is a d012? Should something be replaced? I haven't been able to get a service manual off the internet.
            Thank you
            • habik
              • 2013
              Re: C754 D012 code
              Check if HDD is ON (INstalled in Service Mode)
              Then do a logical format
              Then re-load firmware.
              Firmwares HERE
              • nathicana
                • Aug 2008
                • 329
                Re: C754 D012 code
                So the HDD should be set to on? Is that under state confirmation?
                Where can I get the firmware and instructions on how to load?
                In the future should I select overwrite temporary data instead of overwrite all? It seems so.
                • mthomasebs
                  • May 2017
                  • 65
                  Re: C754 D012 code
                  HDD is under System 2 in Service Mode. Set to Installed.
                  This has also been asked here.
                  For firmware, try signing up at https://infohub.konicaminolta.eu
                  • nathicana
                    • Aug 2008
                    • 329
                    Re: C754 D012 code
                    I signed up,thanks but we are not a dealer. I don't know how to load firmware or if it will succeed with the d012 code displayed. Maybe I can get a manual on the website to help me with that.
                    I also tried turning off the HDD and the machine came up and said ready to copy but would not output a sheet. When I tried running a copy it went on the job list with status "stop printing" and machine said ready to accept another job. Is there a way to get machine to run normally with HDD turned off?
                    • nathicana
                      • Aug 2008
                      • 329
                      Re: C754 D012 code
                      I'm stuck on this C-D012 code. Can anyone can send me bizhub C754 firmware and instructions on how to load it?
                      • copier tech
                        • 8131
                        Re: C754 D012 code
                        If the machine is going back to the dealer & you are worried about security, simply remove the HDD & return the machine without, explain your concerns if asked, most dealers will accept this.
                        • nathicana
                          • Aug 2008
                          • 329
                          Re: C754 D012 code
                          The machine is going to a leasing company and it is supposed to be in running condition. I am a technician but unfamiliar with Konica machines. I ran the wrong overwrite to remove customer's data and got the C-D012 code.
                          • nathicana
                            • Aug 2008
                            • 329
                            Re: C754 D012 code
                            I obtained the firmware and loaded it. The machine now does not display the d012 code. It says ready to copy but after scanning the original machine says "Ready to accept another job" without printing anything. Hard drive still shows installed in service mode.
                            Oil can showing, I touch it and "prt/ir error" comes up.
                            Also I have to enter a password to enter service mode which I didn't before the firmware update. 9272 four times.
                            • Synthohol
                              Certified Konica Expert
                              • 5805
                              Re: C754 D012 code
                              honestly if just going back to leasing company, set HDD to uninstalled, unplug both hdd connectors and boot.
                              likely it will say something like format ssd? say yes.
                              it will copy fine for what the leasing company tests for acceptance but scanning is limited i think but will come to ready, and pass paper. thats all they look for.
                              if it was going into the field i'd make different suggestions.
