BizHub C360 strange one
  • copyman
    Owner / Technician
    • Sep 2005
    • 4708
    I know this machine pretty well but never seen this before (see attach), Print internal demo page and no text on page even though there are black blocks, borders & lines, . Print config and font list they are fine with black text. Customer said every once in awhile some strange things happen when printing, blank pages with a few black lines, etc.
    Not really affecting anything. The issues they have printing is so infrequent it's not a big deal at this point. Just curious if anyone has ever seen this?
    • 23008
    Re: BizHub C360 strange one
    The text is straight K only. The other black parts of the image are composite black, and consequently less affected. Try a monochrome black print. =^..^=
      • 14737
      It is likely the black developer clutch. Replace it and that should fix the problem
      • copyman
        Owner / Technician
        • Sep 2005
        • 4708
        Thanks for the input. What about the config page and pcl/ps font list printing fine. This is black text is it not? All the pages printing internally from the controller just like the demo page.
        • Synthohol
          Certified Konica Expert
          • 5829
          try the test patterns in service mode like gradations and halftones.
          if all are fine reflash the firmware. the test page is built in the firmware.
          good luck
          • allan
            RTFM!!
            • 5462
            Had this before. The text is missing and the K is working fine.
            Fixed it by reseating the ram and connectors.
            Strange..
            Should be fine again after a restart.
            Whatever
              • 14737
              Well, you said it was intermittently producing blank pages while printing black. I was making a suggestion based on the info you provided. If I misunderstood I apologise.
