Konica C224 series Auditron?
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I have a client who needs an 'auditron' for their copier as they have people come into their shop to make copies.
    Is there such a device for the Konica series of A3 colour machines?
  • mthomasebs
    • May 2017
    • 65
    Re: Konica C224 series Auditron?
    Originally posted by jonbonse
    Hi all
    • jonbonse
      • Jun 2009
      • 737
      Thanks but i meant so the user at the till can press the auditron to allow the customer to start copying...
      • jonbonse
        • Jun 2009
        • 737
        They may be called 'Remote Copy Counters'
        • copier tech
          • 8164
          Emos make coin opp machines for copiers, is that any good?
          EMOS Information Systems - Coin Boxes
            • 14755
            Depending on the distance from the copier, all you would need is a card reader and just run the actual reader to the to the til and all the person behind the has to do is use the card to authenticate the copier.
            • allan
              RTFM!!
              • 5462
              You give card with loaded cash of the quantity required or even at a minimum quantity. Get one of those reader setups where you need to drop the card thru a slot.
              50 cards should be good. Still going to need some licensing i guess.
              Whatever
              • oldschool
                • Mar 2007
                • 245
                Something like our True Count would work.
                As long as Vendor II is supported by the copier.
                Jamex Tech Support: Saving the world one phone call at a time.
                • Woxner
                  • Jul 2011
                  • 849
                  vendor 2 is supported
                  • Synthohol
                    Certified Konica Expert
                    • 5836
                    ACDI makes a great model ACD3000 that works beautiful.
                    one wire to the left side of the PRCB and 1 outlet for the brick.
