Konica Minolta AirPrint non "e" models
  • progoffice
    • Nov 2008
    • 336
    I'm setting up a few used non "e" (C364/C454) models for resale. Is their a way to give these models AirPrint capability via firmware etc.? I've recently had to give non "e" models "e" functionality to allow scan to email in Office 365, but I didn't see that it also gave them the ability to AirPrint.
    • 14812
    Re: Konica Minolta AirPrint non "e" models
    As far as I know it isn't possible. Have you suggested Pagescope Mobile for your customers?
    • mdtrinh
      • Aug 2010
      • 68
      I just use an old C450 Fiery (any old PC just fine) to serve as Airprint server.
      - use SATA DVD connect to Fiery to install Ubuntu server (ver 16.04 headless), remove DVD and configure server via SSH.
      - install CUPS (common unix print system), configure CUPS via web browser.
      - install linux printer driver (make sure it configure as share printer).
      - connect Fiery (now is Airprint server) to the same network with the copier/printer.
      - mac/ios device will be able to see copier/printer to print now.
      It can be done with old Fiery using PC motherboard or old PC, no monitor, keyboard, or mouse require.
      Hope this help
      • copier tech
        • 8172
        There is a special "version up" firmware available that gives the non e series the same functionality as the e series, this may include the AirPrint option, you may want to look into that.
        • Synthohol
          Certified Konica Expert
          • 5847
          i have had good experiences with PS Mobile and Hammermill print. just to toss my .02 in the ring
          • Woxner
            • Jul 2011
            • 850
            i could be mistaken but the 4 series did not do air print until e series. you had to update firmware and turn on dip sw. actually is was voice firmware wiich updated the function version
            • B0265
              • Jan 2007
              • 718
              The "version up" firmware supports Google cloud print but not Airprint as far as I know.
              • emujo2
                • Mar 2017
                • 1579
                Hope this help
                Good info, and I used an old Ecopy scanstation for a home PC for some time, but how does this info help with enabling airprint on a non e MFP? It's rare to have an IC on the office MFPs..Emujo
                • mdtrinh
                  • Aug 2010
                  • 68
                  I used Velcro to attach it, and ethernet switch to back of mfp. It provided airprint service to my client with older model mfp without upgrading to the latest model. I also used it to remedy scan to windows 8/10 issue by install smbd on it as file server, then share it thru out the network. My clients are happy camper now, just my 2 cents.
                  • habik
                    • 2013
                    Nice hack...may as well put on some cheap NAS with VM.
                    Firmwares HERE
