Konica Bizhub C451 No Power (Green and orange lit up on scanner but nothing else)
  • Doug James
    • Jan 2012
    • 935
    [Dead] Konica Bizhub C451 No Power (Green and orange lit up on scanner but nothing else)
    Been fighting this for awhile. The customer said this problem occurred after a power surge. I tested the power supply (bottom right of back of copier) according to the manual and it tested bad. Replaced with a known good power supply and still did the same thing. Have no idea where to go from here... Any help would be very appreciated....
  • Woxner
    • Jul 2011
    • 852
    Re: Konica Bizhub C451 No Power (Green and orange lit up on scanner but nothing else)
    MFP is shot
    • mo0651
      • 1054
      reseat/ replace memory chips.
      • Doug James
        • Jan 2012
        • 935
        I actually did that, was sure it would fix it...
        • afterhours
          • Mar 2017
          • 152
          Its definitely your mfp board. Your NIC and NVRAM are all in your mfp Replace it and you will be good.
          Im a Loser Baby!!!
          • Doug James
            • Jan 2012
            • 935
            Sure do appreciate your help !!! Thanks so much !!!
