What does this Print out mean?
  • konica7022
    • Nov 2008
    • 132
    Effects only black
    TB is ok
    Same Black IU if swapped with other machine works fine
    But every Good working black IU that i put in this machine (Bizhub c552) after some time start give black like this
    Sky shoot
  • REGSIS
    • May 2016
    • 435
    Re: What does this Print out mean?
    Originally posted by konica7022
    Effects only black
    TB is ok
    [ATTACH=CONFIG]36917[/ATTACH]
    Sky shoot
    It means that drum is not charging. Since it happens on every dum you put in and that drums are working fine on other machines, you should check HV board (replace if needed) and clean HV contacts.
      • 23010
      Also make sure that the developing unit isn't dumping developer at the front, and sanding the drum surface. I ended up changing out a black developing unit for this. =^..^=
      • konica7022
        • Nov 2008
        • 132
        you mean do all the following
        or is the one in the back Frame and how do i check the voltage?
        • habik
          • 2013
          I'd start with the HV board circuit not the HV contact plates. It is a lot faster. You take the rear covers off and side panel where Network and USB ports are + the whole chassis cage block (MFPB+PRCB+HDD+SSD) Behind that block you'll find HV Board. Replace that one first and see what happens.
          How are your other consumables like? ITB and Devs.
          I had one magenta dev wrecking lot of K devs and TX belts and Drums till we replaced it along with HV Board and FRB (Front Board)
          Firmwares HERE
          • konica7022
            • Nov 2008
            • 132
            i had that problem with another unit Developer dumping i changed the dev unit for that machine that fixed it, but this one is not dumping any thing cleaning laser with micro fiber cloth comes out clean
            • konica7022
              • Nov 2008
              • 132
              ok will try to replace it with another one, other are fine although near end of life, just changed the Yellow IU on that as it started giving a line in the middle
              will i see the result immediately if replace the HV board or could it have damaged the Black Drum/Corona?
              • copier tech
                • 8200
                You say you have tried this drum in another machine & it prints good? So you know the drum is not damaged.
                Before you replace the HVT try another black dev unit first.
                • konica7022
                  • Nov 2008
                  • 132
                  Took Three hours
                  Changed the HV board and still no Difference
                  and the same drum dev when installed in other machine works fine
                  • konica7022
                    • Nov 2008
                    • 132
                    so what does this print mean?
                    • REGSIS
                      • May 2016
                      • 435
                      Took Three hours
                      [ATTACH=CONFIG]36931[/ATTACH]
                      I assumed this is printed image but just in case comes silly question: is this a printed image or copy? Scanned images are OK?
                      And you just replaced HV2 board and not HV1 am I right (according to the picture)?
                      • konica7022
                        • Nov 2008
                        • 132
                        that is just a picture taken from LG g5 to show you the HV 2 board i changed and took the prints (lying under the board)
                        scanning is fine
                        i checked the fusing unit for any marks that seems ok too
                        Only black IU give this issue weather you print or Copy
                          • 14972
                          scanning is fine
                          Have you cleaned the printhead?
                          • ricoh_rockstar
                            • Apr 2016
                            • 18
                            Found this on the Service Manual (See attachment)
                            Did you check the charge corona and PC drum negative contact? Maybe they are broken, misaligned or deformed.
                            • konica7022
                              • Nov 2008
                              • 132
                              as mentioned in the post cleaned the laser and there is no toner or dev dumping
