biz 250
  • Gab
    • Aug 2015
    • 671
    biz 250
    erro 2557 appeared I replaced developer and it is ok but message "add toner" appears .
    I cecked and noticed tat toner adding module doesn't work . No gear is turning.
    Few days ago it was working. I cecked cables and are ok.
    Any idea?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: biz 250
    There is a gear that breaks inside the sub hopper. Not a fun job to do. Easier to swap out the whole toner holder unit / hopper from a parts machine. If just buying parts to rebuild make sure parts are still available since this was deemed "end of life" a few yrs back.
    • Woxner
      • Jul 2011
      • 851
      Re: biz 250
      you cant just replaced dev. you need to replace drum too. then reset counters turn machine off ck counters stayed 0. the run f8. . if you omly do dev and run f8 it will still code
      • copyman
        Owner / Technician
        • Sep 2005
        • 4723
        Re: biz 250
        If I understood correctly the 2557 code is gone and now add toner message won't go out because btl not turning?
        • REGSIS
          • May 2016
          • 435
          Re: biz 250
          Repair or replace 2 solenoids on toner hopper unit.
          It is fun when you love jour job and know what to do!
          • REGSIS
            • May 2016
            • 435
            Re: biz 250
            If drum is OK let's say 50k and developer depleted you CAN just replace developer.
