Scan error bizhub 454
  • devontug
    • Apr 2015
    • 99
    I get this error when ever I try a smb scan don't know what could be the problem as I have setup another with same smb settings...
  • allan
    RTFM!!
    • 5462
    Re: Scan error bizhub 454
    Did you check the job history details?
    Whatever
    • Woxner
      • Jul 2011
      • 849
      what op system are you using ip or computer name. may need soft sw 162 set to hex 2 if using name or firmware update
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        E series or non e series ?
        Welcome to the hell on earth that will be the 50 billion calls for "cant scan to smb anymore" as SMB v1 gets disabled on servers.
        • devontug
          • Apr 2015
          • 99
          Will check which version I'm on so will an updated firmware fix the problem?
          • Woxner
            • Jul 2011
            • 849
            maybe but like i said need to know if its ip or name in which case firmware will work with the soft sw i mention. smb2 /3 can be used
            • devontug
              • Apr 2015
              • 99
              IP address
              • devontug
                • Apr 2015
                • 99
                Still haven't gotten this machine to scan anyone has any idea please and thanks
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4712
                  Did you setup & connect a computer directly to the copier and try to scan to it? This will eliminate the network for troubleshooting.
                  • devontug
                    • Apr 2015
                    • 99
                    Yes I did and it failed
                    • Synthohol
                      Certified Konica Expert
                      • 5840
                      in admin mode turn on network errors to display.
                      report back the actual error code in the job log.
                      • devontug
                        • Apr 2015
                        • 99
                        error code 107 server connection error
                        • Synthohol
                          • 5840
                          if you are scanning by IP, can you ping the server or workstation from the copier?
                          ping is in networking under
                          Network Settings-Detail Settings-PING Confirmation
                          otherwise it may be SMB ver 1 is disabled as mentioned above.
                          • devontug
                            • Apr 2015
                            • 99
                            When I try to ping the machine workstation
                            • devontug
                              • Apr 2015
                              • 99
                              Originally posted by devontug
                              When I try to ping the workstation
                              Ping failed check the connection and settings
