C654 fuser cleaning roller and bushing part numbers
  • sostek
    • May 2010
    • 80
    I have 3 of these with damaged fuser cleaning sections, and found mentioned in a thread that there are parts available , but no #. Looking for cleaning roller, bushings and bearing part numbers.
    Thanks in advance
    Scott
  • copyman
    Owner / Technician
    • Sep 2005
    • 4677
    Re: C654 fuser cleaning roller and bushing part numbers
    See next post. Not sure what happen....
    • copyman
      Owner / Technician
      • Sep 2005
      • 4677
      Here is the only bushing I see A2X0746500. Apparently they changed bushing from metal to plastic due to squeaking noise. Not sure these are for the cleaning roller but suggest changing these as well. I sent you a PM to get your email so I can send you the bulletins that will show you both these parts.
      Here is the cleaning roller part #A2XK740400
      • habik
        • 2013
        Just FYI.
        There is 2 types of bushings as well. I noticed the brown colour bushings ()for cleaning roller tend to last a lot longer. The black (A2XK742901) seem to wear quicker and overall not big fan of any teflon parts made from that type of material. So if possible I am using the brown ones on both C554&654/754 fusers just can't dig the numbers in my laptop. When I find it I let you know. You can use the black bushing as well..just my experience they last a lot less, thats all.
        Duh..COPYMAN has the part number in his post
        Firmwares HERE
