minolta c654 scan/fax and user box just beeps
  • sostek
    • May 2010
    • 80
    more second hand machine joy. have a used c654 that scan/fax beeps and doesn't show on page scope. Any ideas?
  • habik
    • 2013
    Re: minolta c654 scan/fax and user box just beeps
    If you can go to service mode and try diagnostics check. If you can't then try replacing memory modules. Factory reset?
    Firmwares HERE
    • Synthohol
      Certified Konica Expert
      • 5847
      see if the harddrive is physically and electronically installed.
        • 23009
        Check in the service mode to see if the HDD is Set, not UnSet. =^..^=
        • sostek
          • May 2010
          • 80
          that was it blackcat, i was looking in state confirmation for HDD. Thanks a load!
            • 23009
            Congratulations on your success. =^..^=
            • habik
              • 2013
              ah..I've missread your query. I understood it only does scan/fax box and just beeps. My bad.
              Firmwares HERE
