Dp Swich List for KM C452
  • Canonier
    • May 2009
    • 26
    [Misc] Dp Swich List for KM C452
    Hello all
    im trying to find the DP switch list for bizhub c452
    anyone has it ?
    Thank you!!
  • Synthohol
    Certified Konica Expert
    • 5837
    Re: Dp Swich List for KM C452
    its in the service manual?
    • Canonier
      • May 2009
      • 26
      no unfortunately is not.
      i am trying to adjust the rotation speed of the transfer unit because of the classic grey lines on copies.
      it is done by adjusting a dp switch...
      • Synthohol
        • 5837
        what kind of lines? i cant find anything related on SSD. i tried belt, speed, transfer, lines, gray, grey, all separate searches and combinations of all.
        only thing close was...
        Error
        P21
        Root Cause
        P21 with intermittent streaks on copies and prints.
        Workaround/Fix
        CAUSE: HV2 has failed leaving no bias voltage applied to the transfer belt cleaning brush.
        SOLUTION: Please replace HV2 (p/n A0P0 M408 00).
        i didnt know you can adjust belt speed since it has to match up with the fuser.
        • copier tech
          • 8164
          Post a print out of the Bizhub test page, it is unlikely you willneed to adjust any dip switches for a copy/print quality issue.
          โ€‹
          • Woxner
            • Jul 2011
            • 849
            the soft sw are in the manual under service adjustments page I202
            • Synthohol
              • 5837
              those are for CS Remote care, not like normal sw switches
              • Canonier
                • May 2009
                • 26
                Sorry for the delay in my answer.
                i am attaching a scan of the problem.
                the machine has new K unit (both dev and drum.) the transfer unit is relatively new (70.000 prints)
                and this happened. a friend tech told my about a dp switch to change the gear speed of the transfer unit.
                • Canonier
                  • May 2009
                  • 26
                  and this happened. a friend tech told my about a dp switch to change the gear speed of the transfer unit. img007.jpg
                  • Synthohol
                    • 5837
                    what is the issue? the skew? or the bottom of the carton paper effect?
                    • Synthohol
                      • 5837
                      does it happen on all 4 colors?
                      i gotta check, i think it was the c452s that had the printheads "recalled"
                      • Canonier
                        • May 2009
                        • 26
                        (the lines in gray).
                        • Canonier
                          • May 2009
                          • 26
                          No, only in black.
                          • habik
                            • 2013
                            Wasn't this caused by drum drive? or was it on different model.. Think I've seen thread about this.
                            Firmwares HERE
                            • Canonier
                              • May 2009
                              • 26
                              No the drum drive is brand new. and the dev unit also.
                              this lines i think are from the movement of the transfer unit somehow.
                              if you use thick 1 paper mode. the lines are improved drastically.
