Bizhub 421-500 install drum and developer unit
  • shadows
    • Jun 2016
    • 9
    Hello need help
    I install new drum unit and new developer unit on an Minolta Bizhub 421. I run in service mode TCR Adjustment the copier work fine but after 4 day cylinder was broken. I enter in service mode and i enter in service mode at "part counter" and i noticed the developer and drum is with this "--------------" I attach a pictures to see.What is the correct procedure to setup the drum unit and developer unit to install ???? I run only TCR Adjustment , I need to take another step ????
    Thank You .
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: Bizhub 421-500 install drum and developer unit
    drum and developer are supplies not parts, that may be why there is no # listed.
    • allan
      RTFM!!
      • 5462
      What kind of damage. post a photo. That machine is working hard if its done 10K+ in 4 days.
      Whatever
      • shadows
        • Jun 2016
        • 9
        In 10 day the printing volume was 10.500 copies.
        but after i install drum and developer unit i run tcr adjusment , another operation needs to be done ???
        • Woxner
          • Jul 2011
          • 849
          the drum and dev have counters that need to be reset under parts counter before you do the tcr adjustment.
          • shadows
            • Jun 2016
            • 9
            Can you tell me what is the correct procedure in service mode after i install the drum unit and developer unit in bizhub???
            • copier tech
              • 8165
              The correct procedure is listed in the service manual.
              "Service Mode screen"
              Press [Imaging Process Adjustment].
              2.
              "Process screen"
              Press [TCR Adjustment].
              3.
              "TCR Adjustment screen"
              Press the Start key.
              4.
              Check to see if "OK is displayed, and also check the TCR adjustment data value.
              Note
              • The adjustment is completed in about 180 seconds.
              • When there occurs a TCR adjustment error due to the developer agitating operation not completed
              successfully, the message "operating ..." disappears and an error code is displayed
              Are you rebuilding the drum or replacing complete unit?
              • shadows
                • Jun 2016
                • 9
                complete replacing with original drum unit and developer unit
                • copier tech
                  • 8165
                  Your print sample shows lines, the drum is not being cleaned, but this has been replaced.
                  Are you using genuine KM toner?
                  • shadows
                    • Jun 2016
                    • 9
                    No , right now in copyer is not oem bizhub toner
                    • copier tech
                      • 8165
                      • allan
                        RTFM!!
                        • 5462
                        if there is no visible damage to the drum then just check and/or replace the cleaning blade. Could be a very old new unit??
                        Whatever
