ERROR CC-164
  • ck1
    • 485
    [Dead] ERROR CC-164
    C284e show this error code . any idea to solve it ? C284 Mfp board can use for C284e ? thanks
  • rrrohan
    • Sep 2011
    • 1976
    Re: ERROR CC-164
    Cant find that code in service manual
    Sent from my SM-G955F using Tapatalk
    • ck1
      • 485
      Re: ERROR CC-164
      this photo sorry wrong model C280
      • Synthohol
        Certified Konica Expert
        • 5808
        Re: ERROR CC-164
        C-C164
        load firmware on a USB stick
        1. Insert the USB memory to the service port.
        2. Turn on the Main Power SW, then the Firmware Download screen appears.
        3. Touch [Machine Type Select] key on the panel.
        4. Enter [Machine] and [Type] information, and then touch [Fix].
        Check Service Manual for newer models being released.
        ....................C754 C654 C554 C454 C364 C284 C224
        Machine........... 0 .... 0 ..... 1..... 1...... 1...... 1..... 1
        Type................ 0.... 1 ..... A..... 0...... 1...... 2 .....3
        5. Touch [OK].
        6. Turn off the Main Power SW, then remove the USB memory.
        7. Turn on the Main Power SW, then C-D390 is detected.
        8. Let the machine to reboot by itself two times, then the Restore Data key appears on
        the panel.
        9. Touch the Restore data key to restore the data from SSD to MFP board.
        10. Turn the main Power SW off and on.
        UGGGH!!C280? was the wrong FW applied?
        also reusing boards is a bad idea, the MFP or the PRCB could have failed.
        im leaving the info above for any future 4 series that search for this code.
        • habik
          • 2013
          Re: ERROR CC-164
          Just re-write the firmware with correct .tar file. Latest was D2 if memory serves me well.
          Sent from my Mi A1 using Tapatalk
          Firmwares HERE
          • Gerg?
            • Jul 2008
            • 67
            Re: ERROR CC-164
            It means wrong firmware.
