Bizhub C454, Cyan background/ghosting
  • D Colour
    • Oct 2008
    • 213
    [CQ] Bizhub C454, Cyan background/ghosting
    Hi
    Have a problem with a C454 (Olivetti MF452). Its a cyan background or ghosting on the prints.
    ^That is fed long edge first. A4
    ^A3 is obviously SEF
    So far we have tried:
    swapping yellow and cyan drums - no change.
    fitting a used (but known working) cyan dev - no change.
    replaced the transfer belt (used, but working) - no change.
    cleaned lasers and ran multiple stabilisations - no change.
    The machine recently had a new fuser fitted to fix a C3726 error.
    Thinking it could be a bad earth or the voltages are up the left, anyone had this before?
    Everything that has a beginning, has an end.....
  • copier tech
    • 8101
    Re: Bizhub C454, Cyan background/ghosting
    Is this issue just with cyan? difficult to see from your scans.
    Are you using genuine KM toner?
    • D Colour
      • Oct 2008
      • 213
      Hi Copier Tech, the background/ghosting is only cyan yes. I did scan it but it didn't show up at all in those so i took a couple of photos.
      Its is compatible toner in the machine, but this machine (and others) has been running on it for years with no issues. Haven't seen a similar problem in other machines using the same stuff. What are you thinking? I'm open to all possibilities.
      • Max
        • Oct 2011
        • 546
        Fit a new km dev unit and drum so the copier will initialise it and configure for that particula dev unit/drum. By fitting a used dev unit the copier will still use old dev settings. Basicaly no change.
        • habik
          • 2013
          Vac the cyan hopper and run 20 halftones for cyan@255 A3 with no toner bottle installed.
          Check TCR levels %
          When machine asks for toner fit fresh bottle and do manual toner add.
          Run another 20 X cyan halftones and check if TCR % is stable around 6.3-6.6%.
          Now initialise+stabilise background reset and do full gradation adjust.
          If it won't work then replace with new Dev& drum at same time as mentioned above.
          What is the mileage of the Dev unit?
          Sent from my Mi A1 using Tapatalk
          Firmwares HERE
          • D Colour
            • Oct 2008
            • 213
            Hi Habik, thanks for the info.
            There is 447k on the colour devs, so they are far away from needing changed anyway. Will try the above and see how that goes.
            • Albonline
              • Sep 2008
              • 1131
              is the black misting/spewing developer? whats the life on the black drum and developer. have seen this when they are shot. they contaminate the cyan.
              • D Colour
                • Oct 2008
                • 213
                Mono copies & prints are perfect. It had all the drums replaced a couple of months ago. Theres approx 10k on the K drum and maybe 15k on the colours.
                Im not sure about the black dev looking at this (Its at least close to life). The black dev has or has not run over its life - according to the management list, the total count is 572256, but according to the life counter, black dev is 626736. The machine is on a per copy contract so all the life and stops are turned off.
                • Albonline
                  • Sep 2008
                  • 1131
                  if its misting change it out. the colors are setup off of the black. are your color developers especially the cyan depleting? all signs of black problems.looking at you prints i see a ghost image thats whats got me saying you have a hv problem caused by overworn black imaging system.
                  • Quatro
                    • Dec 2015
                    • 78
                    Originally posted by D Colour
                    Hi
                    [ATTACH=CONFIG]38123[/ATTACH]
                    [ATTACH=CONFIG]38124[/ATTACH]
                    Hi,
                    I think you have problem on HV.
                    When you stabilize it shows NG or no?
                    • D Colour
                      • Oct 2008
                      • 213
                      Originally posted by Quatro
                      Hi,
                      Its NG - no good.
                      • habik
                        • 2013
                        Hi,
                        NG Can happen as well when background is set to max.
                        Firmwares HERE
                        • habik
                          • 2013
                          OK let us know.
                          If you have spare HV and K Dev, take it.
                          Before you start changing bits can you print CMYK gradation test and halftones around 60?
                          Firmwares HERE
                          • Quatro
                            • Dec 2015
                            • 78
                            Its NG - no good.
                            Better test the HV and as much as possible if you cab change the DV unit of cyan,
                            As per your sample Cyan is some what like over toner,
                            • copier tech
                              • 8101
                              OK let us know.
                              Poster is using compatible toner, I would always suspect that first before looking at a hardware issue.
