KM bizhub C360 black fading in and out
  • Ingersoll
    • Nov 2008
    • 74
    [CQ] KM bizhub C360 black fading in and out
    I have a KM bizhub C360 with the black fading in and out. Will print 100s of pages fine then just fades out to blank pages, and then black will return like normal.
    I have replaced the black developer, black drum, Transfer belt and transfer roller. It does not give any errors. I am thinking maybe a PCB?
  • Woxner
    • Jul 2011
    • 852
    Re: KM bizhub C360 black fading in and out
    replace the dev clutch it stops and gives light or blank coipes
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      Try the HV pcb if the clutch doesn't work.
        • 23009
        Check the white bushings on the sub-hopper. They can pack up with toner, stalling the toner motor intermittently. Let's see if I have a photo:
        • Tech Helpdesk
          • Jul 2015
          • 112
          Dev Clutch is on its way out
          • Ingersoll
            • Nov 2008
            • 74
            Do you happen to have a p/n for the clutch? I am not seeing it in the parts guide, Just clutches for the paper drive.
            • Woxner
              • Jul 2011
              • 852
              A0EDM20000 it shows in the main drive section. someone can double ck me
              • Hansoon
                • Sep 2007
                • 3391
                Never had to replace any kind of clutch in KonicaMinolta's. I blow them out with compressed air first, soak them with brake cleaner and blow the clutch dry again with air.
                However, when I was working for a company and not paying the part myself, I would get a new part too - but I'm an Indy. Nuff said?
                Hans
                • Ingersoll
                  • Nov 2008
                  • 74
                  P/N for the clutch Blk Dev Clutch CL6? The Parts Manual does not list it, only as a part of the the A0ED-R704-00 Main Drive Assy.
                  • Woxner
                    • Jul 2011
                    • 852
                    i have replaced just the clutch it has a part #
                    • Woxner
                      • Jul 2011
                      • 852
                      ProblemWhen producing only Black & White copies, they are sometimes blank or the black print looks gray.
                      Solution
                      CAUSE: Developing clutch/K (CL6) wire intermittently OPEN.
                      SOLUTION: Replace CL6 (p/n A0ED M200 00)
                      • Desert Rat
                        • May 2008
                        • 1089
                        I have three of these machines and they seem to run fairly good.
                        I just wanted to say thanks for the great post. As an indy I look at
                        just about any machine and don't get a great deal of experience on
                        one product line.
                        Thanks again
                        DR
