Miss feed detected on Konica Minolta C360
  • musthafavi
    • Aug 2017
    • 76
    alternatively getting Miss feed detected message while scanning from ADF (Konica Minolta C360)
    I didn't find out any miss feed, after restarting machine, it will work for while & again getting the same message
    I have attached herewith screenshot
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: Miss feed detected on Konica Minolta C360
    Sounds like one of the sensors is either dirty or lever getting hung up. Did you open the spring loaded door on left underside of ADF and blow paper dust off black felt pad & sensor? When this felt pad has paper dust on it I have seen it cause intermittent jams and other strange things.
      • 23009
      jam code? =^..^=
      • copier tech
        • 8174
        • musthafavi
          • Aug 2017
          • 76
          jam code? =^..^=
          Not showing any error code
          It showing message as I attached above
          "misfeed detcted
          Remove paper indicated by 0"
            • 23009
            Oh, maybe you could print a Management List? Around page 13 you'll find a long list of every jam that ever happened.
            The enduser screen is not of much use unless you turn on DIPSW 30-1 so the machine displays the actual jam code. It's call Collection Data mode.
            • Desert Rat
              • May 2008
              • 1089
              Blackcat,
              Thank you for your last post. I will cut and paste this one in my tech file.
              DR
              • musthafavi
                • Aug 2017
                • 76
                Originally posted by Desert Rat
                Blackcat,
                DR
                Issue has been resolved
                I just reinstalled the Feeder roller and cleaned the ADF by using blower
                Now its working fine..
                  • 23009
                  And still not jam code? This is no use to anybody.
                  Use the resources that are available to you. We all use jam code numbers to identify specific jams. You don't know if you were even in the right part of the machine. =^..^=
