Scan to print Konica Minolta bizhub C284 using gmail business
  • printerpurgatory
    • Jan 2018
    • 23
    [EDIT] Sorry about the title, it's obviously wrong I meant to put scan to email but my brain is so scrambled with this issue, I'm really not a printer/scanner guy, lol. Any help would be really nice.
    Hello,
    I'm trying to get the scan to email function to work on my Konica Minolta bizhub C284 I've tried with and without authentication. If anyone can help that would be great. I've been trying to post this question but haven't been able to see my posts afterwards so I'll wait until I get a response to start posting settings and such. We are using google business so I've tried with authentication off and with "less secure apps enabled". Can someone that's got this working help me?
    Jeff
  • printerpurgatory
    • Jan 2018
    • 23
    Re: Scan to print Konica Minolta bizhub C284 using gmail business
    Here are my settings, and I have the device email and admin email both set to the email account below and "allow less secure apps" enabled on that email account. Thanks in advance
    E-mail TX (SMTP)
    E-mail TX Setting
    Scan to E-mail ON OFF
    E-mail Notification ON OFF
    Total Counter Notification ON OFF
    SMTP Server Address Please check to enter host name.
    Use SSL/TLS OFF SMTP over SSL Start TLS
    Port Number (1-65535)
    Port No.(SSL) (1-65535)
    Certificate Verification Level Settings
    Validity Period Confirm Do Not Confirm
    CN Confirm Do Not Confirm
    Key Usage Confirm Do Not Confirm
    Chain Confirm Do Not Confirm
    Expiration Date Confirmation Confirm Do Not Confirm
    Connection Timeout 30 60 90 120 150 180 210 240 270 300sec.
    Max Mail Size Limit No Limit
    Server Capacity Mbyte(1-100)
    Admin. E-mail Address printer@domain.com
    Device Mail Address printer@domain.com
    Authentication Setting
    POP before SMTP ON OFF
    POP before SMTP Time sec. (0-60)
    SMTP Authentication
    SMTP Authentication Method
    Kerberos ON OFF
    NTLMv1 ON OFF
    Digest-MD5 ON OFF
    CRAM-MD5 ON OFF
    LOGIN ON OFF
    PLAIN ON OFF
    User ID printer@domain.com
    Password is changed. (Password is currently set.)
    Password
    Domain Name
    Binary Division
    • printerpurgatory
      • Jan 2018
      • 23
      I found this researching the issue Gmail Scan Update for bizhub C284 | Transport Layer Security | Booting which says that I may need an updated firmware for the c284 to work with gmail but I'm not sure which firmware version I have and either way I would need a tech that has access to the firmware to install from what I've read. Any suggestions on which one of these lines tells which firmware I have?
      ROM Version
      MFP Card Version A1610Y0-F000-GB0-K8(00)
      MFP Controller BOOT Program A2X00Y0-1E00-G00-01(00)
      MFP Controller Linux Base Linux-2.6.26.8-rt16
      MFP Controller Kernel Program A2X00Y0-1C00-G00-66
      MFP Controller SubSet A1610Y0-1F00-GA0-K5(00)
      MFP Controller A1610Y0-0100-GB0-K8(00)
      Operation Panel Message Data A5C10Y0-8100-G00-K8
      Fax Board Controller1
      Fax Board Controller2
      Fax Board Controller3
      Fax Board Controller4
      Scanner A2XK0Y0-0023-G00-10
      Printer A1610Y0-0050-G10-32
      ADF A3CE0Y0-0024-G00-10
      Finisher A3EP0Y0-0071-G10-03
      RU
      ZU
      Panel CPU A1610Y0-8900-G62-00
      DSC1
      DSC2
      Loadable Device Driver1
      Loadable Device Driver2
      SD
      Voice Data
      Movie Data A2XK0Y0-C000-G00-30
      Dictionary Data
      OCR Library
      Panel Sound Data
      MFP Controller Thread Image Parameter
      MFP Controller PIC Image Parameter
      MFP Controller System A1610Y0-1000-GB0-K8(00)
      MFP Controller Print Controller A1610Y0-3000-G01-46
      MFP Controller Print Controller Font A1610Y0-3F00-G01-40
      MFP Controller Print Controller Demo Page A2XK0Y0-3E00-G00-81
      MFP Controller MIO A2XK0Y0-5000-G00-S4(00)
      MFP Controller PIC A2XK0Y0-8200-G00-11
      • Synthohol
        Certified Konica Expert
        • 5835
        pretty much any non "e" 4 series machine will not work on gmail without changing bit switches and installing 2 sets of special firmware. (which can cause other issues)
        the non e machines are no longer supported by KM so they should upgrade. use this scenario to encourage upgrading.
        office365 and gmail enhanced their security and no longer will accept traffic from devices that are not in compliance.
        most businesses have an ISP, why not use their email info like comcast or verizon or roadrunner etc...
        cant afford to upgrade? scan to SMB and email it from your PC/MAC
        P.S. you have K8 firmware
        • printerpurgatory
          • Jan 2018
          • 23
          Thanks for the reply! I think the scan to SMB sounds like the safest bet. Do you think you can help me get that setup or point me to a how-to, I actually started configuring that earlier today but the how-to that I was following had a slightly different web interface, and instead of searching for another how-to example that matched my web interface I started trying to track down the scan to email issue again. Either way I will work on this tomorrow. It's nice to have a clear answer as to whether or not the scan to email will work on my model. Thanks again, I really appreciate it.
          • Synthohol
            • 5835
            check your PMs.
            • printerpurgatory
              • Jan 2018
              • 23
              I can't seem to get this to work either!! I'm following everything that SMB_setup_guide.pdf tells me to do. I can access the share with the user that I created specifically for the printer. I'm on a domain and have entered in that information. I've changed around the NTLM version from 1 to 2 and with 1/2 setting. Is there any other settings that I should be messing with other than the ones below? Thanks in advance. Also, right now we're just using a USB drive to get our scans, atleast that works
              Client Setting
              SMB TX Setting ON OFF
              SMB Authentication Setting NTLM v1 NTLM v2 NTLM v1/v2 Kerberos Kerberos/NTLM v1/v2
              Default Domain Name DOMAIN
              SMB User Credential Setting ON OFF
              Edit SMB User Credentials Allow Restrict
              User Authentication(NTLM) ON OFF
              DFS Setting Enable Disable
              Address Book (SMB)
              No.
              Use opening number
              Direct Input
              Name
              Sort Character
              Index
              Specify a keyword for address search and display by registered name.
              ABC DEF GHI JKL MNO PQRS TUV WXYZ etc
              Main
              Destination Information
              Host Address Please check to enter host name.
              192.168.11.100
              File Path scans
              User ID printer
              Password
                • 14755
                Client Setting
                Address Book (SMB)
                No.
                Use opening number
                Direct Input
                Name
                Sort Character
                Index
                Main
                192.168.11.100
                File Path scans
                User ID printer
                Password
                Make sure your computer network location is either Work or Private. Also make sure password protected sharing is off. If you are using Win10 these two settings will get changed occasionally by OS updates.
                • printerpurgatory
                  • Jan 2018
                  • 23
                  Thanks for the reply. The share is on a Synology NAS so and don't think those settings are going to apply but of course I could be wrong. Any other suggestions anyone?
                  • printerpurgatory
                    • Jan 2018
                    • 23
                    So I got the scan to SMB to work!!!!!!! I thiiiiiink it was the "Direct Hosting Setting" but I could be wrong as I've been changing so many settings on the device, I feel like I bruteforced it. Well, just wanted to update everyone and not leave you guys hanging/s
                    Thanks for the help!! I'll be back once this stops working and I'm once again in printer purgatory
                    • copier tech
                      • 8164
                      Yes there is a 'version up' firmware release for the non e Bizhubs this enables the e series features including gmail support
                      • printerpurgatory
                        • Jan 2018
                        • 23
                        Yeah, read that there is supposedly 2 firmware updates that need to be done then some bit registry changes for that functionality to be enabled. If you or anyone else could send me these firmware upgrades that would be awesome, ya know, just in case I feel like playing with my printer more.
