Bizhub C358 missing 'Device Comsumables' tab
  • copier tech
    • 8164
    [Misc] Bizhub C358 missing 'Device Comsumables' tab
    Hi all, my question as in the title this tab is missing so no way to view image unit life, is it possible an engineer has disabled this somehow, a SW for example no mention in the CE manual
  • tech51
    • 846
    Re: Bizhub C358 missing 'Device Comsumables' tab
    This does not appear by default on the 8 range. There is a dip switch to enable it, but it requires an engineer to do the adjustment.
    • steve schofield
      • May 2010
      • 117
      Soft switch 227
      hex 00
      • kenpio
        • Dec 2015
        • 201
        We have found this also. We looked through the manual and found that if DIP SW 227 and 230, all the bits are 0. That will make that consumables button appear. Go to switch 227 and change all to 0 and then hit FIX and the same for Switch 230. Hope this helps.
        KEN
          • 23008
          Good to know! Thanks! =^..^=
          • kingarthur
            • 1364
            there's a bulletin TAGB1700562EN about it, think it occurs after FW Function version 3.3,
            • copier tech
              • 8164
              Perfect thanks!
              this site rocks lol
              • mascan42
                • Oct 2008
                • 484
                Why is it that the UK gets all the helpful bulletins and they're never published in the US?
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  Every 8 series i goto that has this crap feature enabled I turn it off so the consumables page returns.
                  I also turn on near life display and consumables reminder for drums since they barely even last the standard life.
                  • giddyupngo
                    • Oct 2014
                    • 109
                    Thanks for this information. I would like to have the button "consumable life" because I like to look at the gas gauges during problem diagnosis. However I don't want a warning on the screen (but an oil can would be OK). From the manual it seems blanking 227 and 230 give you the button AND the warnings and life stops. Is this right?
                    • copier tech
                      • 8164
                      You only need to change sw 277 to enable the comsumables button not sure what sw230 does.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        are we talking about the consumables page in Page Scope or under utility/counter ?
                        • giddyupngo
                          • Oct 2014
                          • 109
                          I'm looking for the one under utility/counter with the little bars representing life remaining, accessible on the operation panel.
                          • copier tech
                            • 8164
                            Yes, so change sw 227 to HEX 00
                            • Kenny
                              • Jun 2009
                              • 529
                              Hi guys,
                              do you know the software switch to disable this consumable life reminder tab?
