Konica Bizhub 363 Says ready to copy then won't print
  • Doug James
    • Jan 2012
    • 935
    [Dead] Konica Bizhub 363 Says ready to copy then won't print
    The scanner will scan the document then comes up with print error on the Job log. I reloaded the firmware formatted the hard drive and unset then disconnected the fax. Th initial call was C0210 LCT Lift Failure. I disconnected the LGC drawer then this is what was to follow. Any ideas would be very helpful... Thankls so much !!!
