c353 image transfer problem
  • lazymangr
    • Feb 2017
    • 115
    Imgur: The magic of the Internet problem is this i removed the trans belt after the print. even when i open the door during the print i get that pattern.machine got like 1mil ticks. i already changed transfer belt and transfer roller. same thing. any clues?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Re: c353 image transfer problem
    Does it happen if you print B&W only, like the internal config test page?
    Looks like you need to replace the magenta imaging unit
    • lazymangr
      • Feb 2017
      • 115
      it happens in every page. even if its halftone, all colors and even on counter list print. this is just a demo. i swapped the iu's too. nothing.
      • bigmikeng9333
        • Dec 2017
        • 2
        Seems like Magenta Developer problem .
        Try to replace it .
          • 23009
          I'm going to make an educated guess that you've lost magenta primary charge. With no magenta primary charge the drum is entirely imaged magenta with no voids.
          The reason copyman asked if it happens on B&W is that the color section of the HVT are disabled during monochrome copies, so black copies should look normal. So what is the answer? Black only copies, what happens? =^..^=
          • habik
            • 2013
            You have covered the IUs, then HVT should be the culprit. Had it once on C258 with yellow, with the difference it blanketed the whole ITB not just part of it.
            Just one thing puzzles me, isn't the meter count printout done with just one PC (K)?
            Does the belt retract when you manually rotate the gear? Anything snapped on M 1st transfer roller? Pressing against the M drum one side only even during K only print?
            Sent from my Mi A1 using Tapatalk
            Firmwares HERE
            • lazymangr
              • Feb 2017
              • 115
              hello. the problem is not in magenta. is on anything i print. in the pic is just a halftone i printed to test. it does that on all prints b/w colored halftone copy print etc.
              • habik
                • 2013
                What does the belt look like when you take it out?
                Sent from portable device using fast cheapset!
                Firmwares HERE
                • lazymangr
                  • Feb 2017
                  • 115
                  i have replaced belt with new and still got the same. all the info guys is on the top post
                  i want to add 1 thing. the problem occurs only on duplex and only on the front side.
                  • Tech Helpdesk
                    • Jul 2015
                    • 112
                    I am assuming that if you stop the toner image on the belt before transfer to the page it is a complete image ?
                    If so the problem lies with the transfer roller and we have had this before, check the springs and the lift cams
                    • lazymangr
                      • Feb 2017
                      • 115
                      thats exactly whats on the pic on the first post. Imgur: The magic of the Internet its a stopped image from a halftone magenta pattern
                      • AjitN
                        • Mar 2009
                        • 287
                        What about PH and PH drive board? OR firmware update AS all color PH are different but board is same.
                        Ideally he should check 80% CMYK patch on A3 and before paper leaves registration assy. stop the machine and check the image on drum.
                        ITB, 2nd Transfer, fusing all are bypassed.
                        Its only Firmware (which I doubt), mfp board which is malfunctioning, PH drive board ( assuming same, identical pattern in all colors)
                        • lazymangr
                          • Feb 2017
                          • 115
                          i went again on machine today since all this time noone has noticed on the customer (lol) and i will upload some more pics
