Biz hub 223 with error C34223
  • axyun
    • Aug 2007
    • 1323
    Did call yesterday on Bizhub 223 with error C3423. The heater lamp has one side with broken element. Is there anywhere a replacement lamp for this series machine as parts unavailable for fuser except for aftermarket rollers and thermistors. Please advise if there is a "fix" for this issue.
    in meantime i will see if I can locate a used unit online. your help is very much appreciated. frank/Action Photocopy
    • 23010
    Re: Biz hub 223 with error C34223
    I think the best that you can hope for, Frank, is that a member might have a corpse in the graveyard with your part still on it. I'd recommend posting the part number if there is a separate part number, or if not post a photo of the thing you desire. Perhaps you can work out an arrangement with that member.
    There aren't a lot of these machines around anymore, and very limited parts, so you might consider selling them something new. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      BIZHUB 223 283 363 423 FUSER UNIT A1UDR70911 A1UDR70922 | eBay
        • 15038
        Unfortunately, sometimes you have to bite the bullet and order a new fuser. We rebuild them as often as we can, but eventually the units we rebuild become too old and ordering a new one is the only alternative.
        • kenpio
          • Dec 2015
          • 202
          I hope that this not true. We still have alot of these out there. We have a hospital with about 30 of this family there. I order these fusers, developers, drums and transfer rollers all the time. I have not seen that they are not available, yet. The problem that we have is that this customer breaks the the exit actuator. Well I have two fusers on the shelf and one in may car.
          KEN
