Bizhub c224e can not access web browser
  • TecnicoPCMassimo
    #31
    • bitels85
      • Jun 2015
      • 9
      #32
      Re: Bizhub c224e can not access web browser
      Originally posted by leprosydog777
      Hello i have a strange problem. My konica bizhub c224e can not access web browser. I tried several web browsers and i updated firmware. And also did a clear all data any suggestions please. The machine can print, scan just cant access web browser i also did a direct connect to laptop to eliminate network still no good please help
      I have two 364e copiers with same symptoms :
      Printing - works
      Ping - works
      Scan SMB - fails
      PageScope Web Connection - fails.
      Steps taken to solve problem:
      1) Uploading Latest Mass FW - didn't solve problem
      2)Deactivate HDD - didn't solve problem
      2) Clear All Data. After Clear All Data first MFP worked fine for short time (SMB and WEB ACCESS ok), second one gave me 'REFORMAT SSD" message (could be important that SSD had been replaced once, because of startup problems - black screen no reaction)
      Afrer Physical and Logical ssd format and restart, SMB and web access worked again, again for a short time.
      After all, I'm at my starting point and I'm loosing hope if ther is any other solution than MFP board replacement
      • Synthohol
        Certified Konica Expert
        • 5814
        #33
        Smb fails right?
        What's the code?
        Is the PC new/upgraded/used before?
        Was there a micro$oft update that increased security to smb 2.0?
        Is the copier set to 2.0?
        There was special firmware and bit switch 219 I remember to lock it in as 2.0.
        Really nothing can be done until you provide the failure scan code in the job log in details.
        Sorry but failed Is not nearly enough info to help you. We need the code.
        If no code shown you must enable scan codes to be shown.
        Check your service manual for how.
        • tsbservice
          Field tech
          • 8002
          #34
          Printing - works
          Ping - works
          Scan SMB - fails
          Try opening PSWC in IE compability mode. Also web connection may be disabled in network or security settings (don't remember) where exactly.
          • rrrohan
            • Sep 2011
            • 1977
            #35
            i had a c364e with same issue. everything worked but page scope
            replaced HDD and did all clear
            problem solved
            i did think it was IT disabling pagescope because the customer loved to fiddle but nope
            • CopierNerd
              • Feb 2015
              • 207
              #36
              Printing - works
              Ping - works
              Scan SMB - fails
              So how did you solve the problem?
              I am facing the same.
