Bizhub c224e can not access web browser
  • leprosydog777
    • Jan 2018
    • 33
    #16
    Re: Bizhub c224e can not access web browser
    Thank you for your suggestions unfortunatley non are successful my machine still can not access web browser im thinking is there special firmware for this solution
    • Synthohol
      Certified Konica Expert
      • 5892
      #17
      back up the address book and do a system data clear.
      you may have to turn the HDD back on in service mode and load the movie data but if that does not fix it you need a new MFP board.
      /.02
      • rrrohan
        • Sep 2011
        • 1977
        #18
        id reload firmware = yes
        can yiu print = yes
        can you ping
        are you using IP or hostname
        you certain another device doesnt have identical IP. = you ruled this out using crossover
        does data administrator work
        have you tried http://IP/ and https://IP/
        • leprosydog777
          • Jan 2018
          • 33
          #19
          /.02
          Hello yes i turn off hdd and also ran a all system clear still no good
          • leprosydog777
            • Jan 2018
            • 33
            #20
            can yiu print = yes
            can you ping
            yes it can print and scan to email i changed ip even static no good and yes i connect laptop crossover all browsers have the path on web bar but wont pull up the index just a white screen
            • allan
              RTFM!!
              • 5462
              #21
              Did you check that the HTTP server is switched on??
              Whatever
              • habik
                • 2013
                #22
                What firmware are you having on machine at the moment and what were you loading on?
                Is the PSWC set to ON? (Admin>Network>PSWC)
                Is or WAS the machine set by any chance to Management Function Choice other than Default? i.e. Vendor mode / Key counter etc..
                If it was, some features may work prints/scan despite being disabled in Service Mode as it keeps the previous settings as default. Have a look at the Billing section under Enhanced security in Service Mode.
                Whats the HEX reading on SSW63? (Service>System 2>Software Switch Setting)
                Firmwares HERE
                • leprosydog777
                  • Jan 2018
                  • 33
                  #23
                  Hello thank you for all of your suggestions i found out it was the memory card i swapped with another machine test and now i have browser so thank you again
                  • copier tech
                    • 8200
                    #24
                    • Synthohol
                      • 5892
                      #25
                      UK-211 or the like. the 2 gig ram that enables browser and other functions.
                      • leprosydog777
                        • Jan 2018
                        • 33
                        #26
                        yes the 2 gig ram card when replaced now i have web browser
                        • Synthohol
                          • 5892
                          #27
                          LOL, ya know we could have solved this on the first page if you specified using the "web browser" feature on the copier.
                          we all took it as you cannot log on to the copiers web page from a computer.
                          just for future clarification
                          • copier tech
                            • 8200
                            #28
                            Exactly! That is a rare option out of 1000+ Bizhubs none of my customers have it!
                            Its included on the 8 series now!
                            • leprosydog777
                              • Jan 2018
                              • 33
                              #29
                              I did clarify read my first post i could not log in web browser using computer thru network and posts after saying a crossover
                              • Synthohol
                                • 5892
                                #30
                                right but the UK-211 ram should not stop you from opening the copiers webpage.
                                glad you got it sorted though
