C352 issue...
  • blax
    • Mar 2013
    • 78
    C352 issue...
    i am getting: "printer is in an error state", i replaced DIMM modules from another machine, cleaned boards, and rough memory check is ok, but we can not solve it... any ideas?
    machine have attached a IC-406 fiery device.
    thanks!
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: C352 issue...
    sorry, thats too vague.
    where are you getting the error message? copier control panel or command workstation?
    have you logged into the emperon controller to see more error details? sometimes its in red on top of the page.
    • blax
      • Mar 2013
      • 78
      Re: C352 issue...
      i get the error on control panel lcd, machine can do copies, work fine with fiery remote scan, but 0 print pages from computer, was working fine but started to fail when just first page printed from a 10pages document, and now we can not print any pages... emperon do not show anything... in the driver window appear; machine is in an error state when i send a printjob...
      machine was working fine with IC-406_PS_Win2K_XP_32_64_Vista_32_64_Ver_1.01s driver
      • blax
        • Mar 2013
        • 78
        Re: C352 issue...
        the problem is i only can print 1 print job, if i send more, command wordstation freezee, and emperon, shown error state...
        any ideas?
        • Albonline
          • Sep 2008
          • 1147
          Re: C352 issue...
          any ideas?
          hdd?
          • blax
            • Mar 2013
            • 78
            Re: C352 issue...
            i suspect is fiery ic406 module, but i dont know how to made a diagnosis of fiery
            • Synaux
              • Mar 2012
              • 1224
              Re: C352 issue...
              Have you tried turning it off and on again? If so, are you saying after each reboot, you can only print one job then it goes to error state in the print que?
              "i get the error on control panel lcd" what is the error?
              Try PCL drivers to eliminate driver related issue.
              Does the 406 have led codes on the back side where all the cable hook up to it? If so, what does it show?
              • blax
                • Mar 2013
                • 78
                Re: C352 issue...
                on lcd screen of c352 if i print more than 1 file, then appears the code involving extraction hardware timeout, that code referal about DIMM or board replacement, but i tried with another memmory modules and memory is not the failure reason...
                i have installed PCL drivers and same issue...
                fiery just have 1 green led, and always is green... each time i need print a file, i need restart the machine...
                machine was working fine for 2 years, but recently started to experiencing this failure.
                if i remove the fiery to check if fiery is the reason, do i need to setup something in service mode? something like "uninstall board" or so?
                  Re: C352 issue...
                  is there a numerical error code to it? what is the EXACT message?
                  • Synthohol
                    • 5808
                    Re: C352 issue...
                    in command workstation, run a "clear server" that will clean up the HDD in the fiery.
                    you can also do a backup on the fiery so it will save all the settings then restore to factory and print a config sheet because it went back to DHCP so you can restore your settings.
                    also when printing i hope its set for LPR with Print as the queue. thats the correct way.
                    also if the fiery is giving the copier its IP address have you tried printing directly to the machine (emperon) to eliminate the fiery as to this issue?
                    if you think its the fiery, run a fresh copy of system software so the Fiery will be like brand new.
                    also fwiw i have had those controllers where the CPU cooler gets so filled with dust and hair it will overheat and do wacky things.
                    even had one where the leg of the cooler fan broke so the heatsink was barely touching the CPU.
                    if your fiery is set to retain 99 jobs (some do by request) there is little room for the jobs to RIP.
                    try the clear server first, archive whatever jobs you neede to keep locally to a PC and see if clearing the server helps.
                    if you decide to try system software, i can help you out, just become a $$ contributor to this site (ya get a cool badge on your avatar) so we know you arent just looking for a handout.
                    • Synaux
                      • Mar 2012
                      • 1224
                      Re: C352 issue...
                      Exactly!
                      Everything that Synthohol said, but I would also add to be prepared with compressed air-can or air compressor (do NOT use a vacuum) to clean up all the dust/hair/etc. Also, I strongly recommend taking the heatsink off the CPU and cleaning off that garbage thermal tape and apply a quality thermal paste. If you are not computer savvy enough I am sure a computer shop will do it for pretty cheap. That is pretty unfortunate that this model does not have code-LED on the back--that feature can be very helpful.
                      Anyways, you can change the Image Controller Setting in System 2 in Service Mode to "Controller 0" to use the standard controller ("Controller 1" for fiery)
                      • blax
                        • Mar 2013
                        • 78
                        Re: C352 issue...
                        error C4765
                        • blax
                          • Mar 2013
                          • 78
                          Re: C352 issue...
                          yes, i will contribute, no idea before about $$ avatar hehe until you said
                          and yes, i back the fiery to factory defaults, all files inside HDD were erased, and re-setup ip address ( i was printing using emperon and CWS, both methods)
                          i will try remove the entire fiery unit and clean inside... service as a normal computer, clean dust, check fan impedance, heatsink grease, and so, many factors about thermal overheat just to discard dust or so..
                          • blax
                            • Mar 2013
                            • 78
                            Re: C352 issue...
                            yes, i h ave all materials to do service for the unit, i never opened the cabinet but you are right, this ic-406 was released on 2000-2002, so should have tons of dust inside. after a big clean, which CPU temperature should be the right one? i can use a thermometer to see overheat.
                            Service Mode -> System 2 -> "set Controller to 0" = standard controller (<-- is this the internal machine controller right?)
                            Originally posted by Synaux
                            Exactly!
                            • Synthohol
                              • 5808
                              Re: C352 issue...
                              yes controller 0 is the standard built in controller.
