Fitting a C454e fuser to a C224e model
  • copier tech
    • 8144
    [Electrical] Fitting a C454e fuser to a C224e model
    Quick question, is this possible? different part numbers for both fusers but they look the same!?
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Fitting a C454e fuser to a C224e model
    i remember the 3 series you could put a faster fuser in a slower model, the heat lamps were a higher wattage, you just couldnt do the reverse because it couldnt keep up.
    the 4 series has no lamps so trial and error? are they geared exactly the same? i never took notice.
    • copier tech
      • 8144
      The 4 series DOES have a lamps, a pair of them.
      • Synthohol
        • 5824
        honestly i never took one apart, i thought the whole induction thing did it all.
        my bad.
        • copier tech
          • 8144
          I only found this out because I had dead new unit, turns out lamps were broken so fitted another lamp from an old unit!
