Bizhub C452 Specific error
  • ncbabak
    • Apr 2014
    • 43
    [Misc] Bizhub C452 Specific error
    Hello Friends
    I have a problem in konica c452 Specific noise on prints,like test below
    I checked transfer, fuser,Images
    In your opinion Is it possible firmware or NvRam?
    Someone can help to fix this problem
    Thanks!
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: Bizhub C452 Specific error
    Go into service and print out separate color test prints. The color that shows the lines need to replace that Image unit or black drum since that drum is sold separate unlike the color IU's where drum is inside unit.
    • ncbabak
      • Apr 2014
      • 43
      Thanks dear friend for answer
      When prints separate color test , prints are ok
      but when print picture or test print error is still come back
        • 23010
        I see the flaw equally in all colors, especially visible in the 30% and 80% fill blocks. For it to affect all colors equally it would have to be primary or secondary transfer. Which way did the paper feed? If the voids are crossfeed (Letter-R, SEF), you might have a primary transfer drive problem. =^..^=
        • ncbabak
          • Apr 2014
          • 43
          thanks all
          The error was removed by replacing the black drum
          While there was no s
          cratching in the drum surface
          • copier tech
            • 8200
            Originally posted by ncbabak
            thanks all
            Interesting fault, thanks for the update
