Biz C454 saddle stitch ?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4788
    Think I'm like most techs and don't know much about the advanced end user stuff with copiers. Mostly know the basic stuff like 2 side, finishing/stapling, etc
    Had a customer come to shop to look at this C454 to buy. The main thing they said it needed to do was "copy" and saddle stitch a 8.5x11 6 page booklet they brought with them. I said no problem, easy. Lol, I spoke too soon. I removed the 2 staples and separated the 6 pages, put them in doc feeder "R" direction, selected booklet/staple, but when I hit OK for the settings it keeps wanting to reduce it to 64%. If I change it back to 100% it is off the page. Tried all different stuff looking like a fool for like 30 mins, then told them I would have to get back to them. My thinking is if this booklet was produced on a copier I should be able to copy it?
    Funny I had all the usual demo stuff ready for this customer, test charts on a USB drive, different types of thick paper, 2 sided originals, etc and all they cared about was doing this booklet. Ha-ha. Hopefully it can do it or I lost a sale!
    Thanks in advance
  • Flash
    • 378
    Re: Biz C454 saddle stitch ?
    Since the document is already in booklet form you just need to select 2-sided to 2-sided and select center fold and staple.
      • 23010
      You're using two-up originals. That is two page images on each original. The booklet function is designed for one-up originals, or one page image per original. It's simple enough to lay out your originals one-up, or copy 2-2 duplex like flash suggested. =^..^=
        • 15068
        There is a setting in user mode where you can turn the auto booklet mode off. I can't remember the exact buttons to push. It is called "Auto booklet on when fold and staple" turn it off and it will allow you to fold and staple exactly what you put through the DF
        • Don N.
          • Nov 2011
          • 409
          GAWD I wish I had this thread last time a customer ambushed me with that crap! I like to tell them "It's like Nascar. I'm the mechanic and you're the driver! I'll be glad to check the USER manual, you know, the one we gave you when you bought the machine? They don't include much USER stuff in the SERVICE manuals"
          Have to get back to you, or have someone in sales help you...
          Am I the only one?
          I did learn that the SD options I've seen (I have only sold a few) only fold about 4 sheets of plain paper, and won't fold much or any thick paper.
            • 23010
            Correct. Limitation is (1) 52-209gsm cover page with (19) 52-90gsm pages or (20) 52-90gsm pages.
            It seems like the folks that buy these finisher/saddlestitchers want to print 50pgs of 199gsm media... and it just won't. =^..^=
            • copyman
              Owner / Technician
              • Sep 2005
              • 4788
              Thanks to everyone that replied. I'm almost there with changing the auto booklet setting to off . Now 2nd side of every page is upside down, but in correct order.
              I put 4 double sided 8.5x11r originals in feeder, select duplex 2 to 2, select staple & fold. There must be one more setting so it doesn't turn 2nd side upside down?
              Thanks again
              • Synthohol
                Certified Konica Expert
                • 5922
                put in feeder portrait, select the landscape tray (r) and the auto rotate should take care of the rest.
                  • 15068
                  Thanks again
                  All you have to do is change the bind position. I think left bind is the one you want, but you may need to experiment.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4788
                    Thanks copier addict. Left bind worked !!!
                    • Blizzoo
                      • Aug 2013
                      • 611
                      Just wanted to thank you for bringing up this thread, this helped me to successfully demonstrate to customer how to copy an A5 booklet to their Toshiba MFP after some trial and error , I knew I have been read this thread before here on CTN.
