C451 IUs Reset Problem
  • mdtrinh
    • Aug 2010
    • 68
    I am facing a strange problem as never happen to me before.
    - Copier shown with IUs (yellow, magenta, cyan) need to replace pop up message.
    - Make a color test pages, they look sharp & clean.
    - Replace reset chips to each IU to reset pop up message.
    - It shows C255B (IU yellow TCR adjustment error), clean sensor -> no good, install old chip back.
    - C255B error gone, but C255A error show up, install old magenta chip back.
    - C255A error gone, but C2559 error show up, install old cyan chip back.
    - Now, everything function normal, all TCR levels around ~ 7.0.
    I am back to square one with the pop up message.
    Please help
  • Synthohol
    Certified Konica Expert
    • 5898
    Re: C451 IUs Reset Problem
    turn off consumable life reminders.
    or god forbid replace them with new ones not just the friggin meter chip!!!
    • mdtrinh
      • Aug 2010
      • 68
      Already tried setting according to tech bulletin # 8607, only this copier still shown, others 5 machine were off in life reminder.
      Copies still look good & clean, why waste good ius, try to be environmental friendly.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4773
        Possible chips labeled wrong, and not for that model? Anytime chips are replaced, especially on these older models anything can happen but for all 3 chips to code out is very strange and makes me think they are wrong chips. Did the quality look good before chipping?
        I would try chips from different supplier. Worth a shot, a lot cheaper then new IU's !!!
        • mdtrinh
          • Aug 2010
          • 68
          Yes, it looks sharp & clean before chip, re-install old chips for now to avoid machine down until it can be resolved.
          At this point, everything work but annoying pop up message.
          • Synthohol
            • 5898
            is the firmware the latest? or the same as the successfully message free ones?
            • mdtrinh
              • Aug 2010
              • 68
              Yes, it is same firmware with the rest of other machine and I cannot figure it out why it is after checking firmware, setting.
              • Synthohol
                • 5898
                print the list output for both machines and compare the bit switch pages.
                • Blizzoo
                  • Aug 2013
                  • 611
                  I know that if you put new chips on used IU's the machine will consider the IU's are new and adjust the TCR lever wich fails due to the fact that the units are already used.
                  • copier tech
                    • 8204
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4773
                      Sometimes even with F/W updated on these older models if you wait until replace IU messages are on display they will not turn off. Then only alternative is to chip them. Been there done that many times! I have also replaced the chips countless times and never had any issues with TCR, etc. The IU's last another full cycle after new chip. Also had a few C451's that IU's ran to 500k+ with messages turned off.
                      The only time I had real issues with chipping IU's was with the C250/252. This was hit or miss with the result.
                      • mdtrinh
                        • Aug 2010
                        • 68
                        You are right, I just copy data from used unit (only showed one bar usage) to previously TCR problem chips. and it works.
                        Now, I have some used IUs unit data to play around, avoid using brand new unit data as previously done.
                        Thanks guys
