C454e Firmware
  • copyman
    Owner / Technician
    • Sep 2005
    • 4685
    C454e Firmware
    I have a machine that I'm getting ready to deliver. Everything is working good. Firmware is G20-C8. After checking on K/M website I see several newer versions. Should I leave well enough alone since everything is working good or update? If i do update do I need to do in steps?
    I know I sound a little paranoid but as I explained on this forum before F/W don't like me and I don't like it ! Must admit updating has become much easier with USB than back in the CF card days.
    Anyway thanks for the help.
  • Woxner
    • Jul 2011
    • 848
    Re: C454e Firmware
    just read the pdf first sometimes certain soft sw need to be done first. i know guys just jump to the latest but if things arent done right it may not work right
    • copyman
      Owner / Technician
      • Sep 2005
      • 4685
      Re: C454e Firmware
      Thanks wox. Exactly why I asked. Thought I heard of some problems if not done in steps (not sure if this model). And with it having such an old version now I didn't want to update to latest and open a can of worms. This is probably close to original F/W.
      I did read some of the notes in the Read-me pdf. If you try and read this you'll see another reason to dislike F/W. You could spend an hour reading it and still don't understand it!
      • Synthohol
        Certified Konica Expert
        • 5823
        Re: C454e Firmware
        we've been putting the latest G20-M1 with no issues on hundreds of these machines.
        • habik
          • 2013
          Re: C454e Firmware
          E series are pretty straight forward.
          Just go one by one through mass production firmwares. Just delete the movie data and don't worry about the function enhance function soft switch 25 for now. They all have equal functions. Once on the top level of firmware, change soft switch 25 to your desired function, think FE 7 HEX 60 if remember correctly.
          One thing I would point out is the update of SSD. THERE IS ONE MASS PRODUCTION firmware that "should" take you on the latest version of SSD driver ver.6.05m this will show on the last page of firmware version in service mode. I believe G20-G9 was the one that did that. If not sure read the SSD upgrade procedure first before you start Mass production firmwares.
          Ensure you go from Mass production C8 to E4 to G9. J was I think skipped for compatibility issues and there is a lot of K's. Then M1 and you done. Unless there has been a newer version since.
          Hope this helps a bit.
          Sent from portable device using fast cheapset!
          Firmwares HERE
          • habik
            • 2013
            Re: C454e Firmware
            From K up probably, from C, I would go with SSD check and then E,G then maybe one K at least and then M.
            Firmwares HERE
            • antone
              • Oct 2014
              • 344
              Re: C454e Firmware
              Read PDF
              Sent from my SM-N950U using Tapatalk
