Fiery showing FF on c6500 ic408
  • swaggen
    • Sep 2017
    • 100
    Looks like I need a hard drive or Reload the software and my tech is 3 days out.
    I am looking to operate the printer without the controller , direct from server or PC.
    Is that possible? I am being told yes and No.
    I have gone into the dip switches DIPSW 2-1 (1) On
    Set my NIC Ip to a range that is will pick up.
    Connected to the appropriate LAN on the machine.
    Is it futile? Can you only print via a controller?
  • Toxic
    • 697
    Re: Fiery showing FF on c6500 ic408
    As i know it is not possible to print without controller.
    And this is logical because why people would buy a expensive controller if it can be printed without it.
    • Synthohol
      Certified Konica Expert
      • 5824
      do you have/need system software?
      i can help you out if you are a contributor to this site.
      just an offer.
      • swaggen
        • Sep 2017
        • 100
        just an offer.
        Sure I would like to contribute and I appreciate the help. How do I do that best?
        • Synthohol
          • 5824
          top of the forum.
          ill send you the links to my server.
          • ipicopier
            • Jun 2018
            • 21
            Hi,
            I will contribute if its possible to send a download link to the c6500 ic408, my RIP went crazy and have been trying to get this file..
            Thank you,
            Rak
            • Synthohol
              • 5824
              ill send you the link when i see the badge
              thanks for considering.
              btw ask anyone here, i always follow through.
              • Copy Bargain
                • Nov 2019
                • 4
                Fiery boots up and shows FF error sometimes, but always works if I reboot the printer and then the fiery while the printer is warming up. BUT, I can't send any files much larger than 1MB to the fiery!!? And if I send anything larger it takes hours to load into the fiery, OR the fiery disconnects.
                Archived jobs in the fiery print just fine, is this a system software issue? A HDD issue? Or should I just upgrade to the external fiery ic-305?
                I don't have the system software, and I'm not sure of what HDD to get if I have to replace that too.. I can get the ic-305 for $1300 if I trade in my malfunctioning ic-408 from an ebay seller --> Konica Minolta FIERY IC-305-PLUS* Server *UPGRADE* from IC-408 X3eTY2 Controller | eBay
                Not sure what to do as I have to print many jobs this next week.. :/
                Any feedback/assistance would be greatly appreciated!
                Thanks!
                • Synthohol
                  • 5824
                  just an offer.
                    it's true.. he has the sweetest golf swing follow thru I've ever seen!
                    seriously tho... If Synth says he'll send the files when you Contribute, you'll get them!
                    sorry early morning humor.
                    • Synthohol
                      • 5824
                      I have for the ic408 versions 1.1 and 2.0
                      Do not try 2.0 unless you have had the bios and ram upgrade already installed.
                      Just 1 contributor badge away from getting that fiery up and running
                      • Copy Bargain
                        • Nov 2019
                        • 4
                        Thanks guys! I'm happy to contribute! Now how do I go about reloading the software on the the "Bolt-On" IC-408 Fiery server??
                        Best,
                        Romeo
                        • Copy Bargain
                          • Nov 2019
                          • 4
                          Currently, my Server Info is:
                          Password Enabled: Yes
                          Memory (MB): 1024
                          Software: EFI Fiery System 8 Release 2
                          Version: 2.0
                          Disk Size (MB): 60016
                          Free Disk Space (MB): 51937
                          • Synthohol
                            • 5824
                            I sent you a link to the system ver 2.0
                            Enjoy
                            And a 2nd pm for the instructions.
                            Thank you very much for contributing!!!
                            • Copy Bargain
                              • Nov 2019
                              • 4
                              Enjoy
                              Thanks Synthohol! I didn't even need to restore the software! When reading the instructions, I ran across the section for printing out the configuration settings to prepare for the reconfiguration, and out of curiosity I started comparing the settings from now to 3 years ago and noticed that the darn network Ethernet speed was incorrect!!
                              It's been 5 months holding off and thinking my Fiery went bad! What a relief!!
                              Thank you so much though! You still helped lead me into a solution, and I still have the software JUST IN CASE!
