Fiery showing FF on c6500 ic408
  • mariuscmr
    • Apr 2017
    • 13
    #16
    Re: Fiery showing FF on c6500 ic408
    I'm also interested in the software image after a HDD crash. I managed to clone the OS and Backup partition, but the one labeled "Fiery" has got a lot of bad sectors and unreadable files. It's for Fiery X3eTY2-10. Can I get it, please, if I also contribute?
    Thank you!
    • Synthohol
      Certified Konica Expert
      • 5824
      #17
      Originally posted by Synthohol
      I have for the ic408 versions 1.1 and 2.0
      Do not try 2.0 unless you have had the bios and ram upgrade already installed.
      Just 1 contributor badge away from getting that fiery up and running
      Still applies.
      • Walterj
        KONICA MINOLTA
        • Jun 2017
        • 89
        #18
        Originally posted by swaggen
        Looks like I need a hard drive or Reload the software and my tech is 3 days out.
        I am looking to operate the printer without the controller , direct from server or PC.
        Is that possible? I am being told yes and No.
        I have gone into the dip switches DIPSW 2-1 (1) On
        Set my NIC Ip to a range that is will pick up.
        Connected to the appropriate LAN on the machine.
        Is it futile? Can you only print via a controller?
        good day
        The error presented by your fiery must be due to the defective HDD, I recommend you replace it and load the operating system.
        You can write to me at walvaradocruz@gmail.com
        Greetings.
        • Synthohol
          • 5824
          #19
          you are responding to a user's post from 3 years ago.
          please check the date of posting if you are quoting someone.
