Samples of image problem Bizhub c452
  • chawqi
    • May 2018
    • 20
    Re: Samples of image problem Bizhub c452
    Any way, thank you but if you should be in place place you will do the samething because techs I know are not qualified in my point of view that's whay I decide to understand and learn more from you all my life I like knowing things.
    • Bix
      • Apr 2018
      • 1421
      If you like this work I suggest you this section of the forum: http://www.copytechnet.com/forums/employment/
      • chawqi
        • May 2018
        • 20
        Thank you for you orientation
          Originally posted by chawqi
          The inial problem was that the machine couldn't print, and I was advised to format HDD, since then I've got problems
          it wouldn't print so you formatted the HDD?
          did you even BOTHER to check to make sure your network was configured correctly?
          you caused these problems yourself... then you don't want to trust techs here? DONE WITH PEOPLE LIKE YOU!
          • Albonline
            • Sep 2008
            • 1135
            #20
            Golly , just a little bit hostile here, give the poor guy the benefit of the doubt and try to help him out.
              Excuse me for my interference
              The Technician I have called couldn't resolve this problem
              then you weren't talking to a KM tech!
              • chawqi
                • May 2018
                • 20
                #22
                To phil b
                in our country a proverb say : knowig things is better than ignore it. all my life I beleive that man should know many things since he is living. furthermore, to make you informed very politely that finally i managed to fix the problem with the help of cource of guys here an other time thank you guys.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4546
                  #23
                  Not sure how much assistance can be offered here. This is one of those things hard to explain step by step on internet.
                  I understand it may be hard to find qualified techs in your country. If you do not have service manual than you need to get that first. As the other poster said you may have to setup machine like it just came out of the box, making all adjustments. Also don't always trust firmware from internet or if you put in wrong USB slot can also cause problems.
                  • chawqi
                    • May 2018
                    • 20
                    #24
                      To phil b
                      and we have a saying in our country FUCK POLITENESS ! put your big boy thong on ... grow a set.
                      • cog5
                        • Oct 2017
                        • 4
                        #26
                        [QUOTE = chawqi؛ 604237] مرحباً بالجميع
                        هنا هي نماذج لمشاكلي في النسخ
                        Sample 1.jpgsample 2.jpg[/ QUOTE]
                        • cog5
                          • Oct 2017
                          • 4
                          #27
                          Follow the steps in order
                          Please pay attention when placing the paper be linear
                          CAUSE: Improper setup procedure.
                          SOLUTION: The setup procedure in the original installation instructionsis incorrect. Please perform the following in the order listed:
                          1. Touch Panel adjustment.
                          2. Gradation adjustment.
                          3. Date/Time Setting (Service Mode then Administrator Mode).
                          4. Install date.
                          5. Serial number input.
                          6. Unit change setting.
                          7. List output.
                          Details of these adjustments are found in the Installation or Service Manuals
                          • chawqi
                            • May 2018
                            • 20
                            #28
                            thank you very much
