biz 501
  • Gab
    • Aug 2015
    • 671
    biz 501
    I want to replace opc drum . I need to get in service mode and clear drum counter as service manual says.
    I select utility/counter, meter count, stop 0,0, stop, 01 and machine asks for CE password to be set.
    I insert 0000000 or 12345678 but wrong code number .
    I took over service for this machine from others . Before me others provioded service. Also it's a second hand machine.
    When i give 12345678 or 900000000 i can get in administrator mode .
    Previous service say's that's all he knows.
    Any idea how to get in service mode?
  • Toxic
    • 697
    Re: biz 501
    Did you try 92729272 ?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4677
      Re: biz 501
      Your post wasn't clear, are you putting in "8" zeros? Once you get into service mode you can go into enhanced mode and change password or turn off.
      • Gab
        • Aug 2015
        • 671
        Re: biz 501
        I am trying to get in service mode but it asks for code i tried 8 zeros also 12345678 but machine says wrong code.
        If the right code is lost do i have to replace ram?
        I just refer when i try to reach administration and asks for code i write 8 zeros or 12345678 (i don't remember which one of these two" ) and now it is accepted.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4677
          Re: biz 501
          Not sure if this will work but after "stop 0 0 stop 0 1" try "stop" "0" "clear" and see if you can get into enhanced mode. If it works you can change or turn off the "CE" password.
          If nothing works you will have to change NVRAM.
          • Gab
            • Aug 2015
            • 671
            Re: biz 501
            Is there the ability to cancel or change CE password when i can get in Administrator ?
            giving 8 zeroes i get in administrator menu. Can i clean CE password there?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4677
              Re: biz 501
              No you can't change in Admin mode. You need to get into the enhanced security mode
              • Gab
                • Aug 2015
                • 671
                Re: biz 501
                I think enhanced mode is in admin mode.
                If i get in enhanced mode whice must i select to cancel ce password.
                • darry1322
                  • Oct 2010
                  • 817
                  Re: biz 501
                  You can't reset CE password in Admin mode. Enhanced security or no. Did you try 92729272 as earlier suggested?
                  • Gab
                    • Aug 2015
                    • 671
                    Re: biz 501
                    ?Yea i have tried 92729272 with no result.
                    • Bix
                      • Apr 2018
                      • 1421
                      Re: biz 501
                      And 927292729272?
                      • Gab
                        • Aug 2015
                        • 671
                        Re: biz 501
                        Originally posted by Bix
                        And 927292729272?
                        I replaced only opc drum and blade (the previous was scrached by the customer) and the copy is light (it was ok with the replaced drum) . I didn't cleared drum counter because as i said above previous tech didn't give me the CE password!!!! At the moment i can't replace nvram (for some reasons). Is there any way to darken image ?
                        Also today i saw a post about nvram . Can i reset it? If i reset or replace it do i have to replace developer and what other adjustment i have to do?
                        • Synthohol
                          Certified Konica Expert
                          • 5817
                          Re: biz 501
                          16 digit passwords didnt come until the 4 series.
                          try 92729272
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4677
                            Re: biz 501
                            Sorry to say the only way to darken copy is reset drum counter. The machine's voltage correction settings are still set for the old drum. See if you can buy the MFP & NVRAM together (both from same machine) on ebay or somewhere. Can't be that much for a 10 yr old machine. Heck I could of bought a whole working 501 for $50 a few years back!
                            • Synthohol
                              • 5817
                              Re: biz 501
                              the 501, didnt you have to set the charge voltage to whats printed on the drum flange?
                              been a while since i saw one.
