biz 501
  • copyman
    Owner / Technician
    • Sep 2005
    • 4675
    #16
    Re: biz 501
    Hey Syn, you may be right. Been awhile but I seem to recall that. Last one I worked on was a 421 about 3 yrs ago. What I meant was as the drum counters click & drum wears doesn't the machine adjust the voltages to compensate for drum wear? Unless I misunderstood the poster said CQ was fine and only replaced the drum because of a scratch, and since he can't get into tech rep mode the "compensated" voltages would still be for that used drum, and maybe why the copies are light with the new drum. Just a thought throwing out there. Kind of a moot point with not being able to get into serv mode, this machine will never be able to perform well anyway.
    • Synthohol
      Certified Konica Expert
      • 5816
      #17
      Re: biz 501
      never did perform well to begin with!
      and that damn toner bottle and hopper.
      they should all catch fire and burn in hell.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4675
        #18
        Re: biz 501
        Ha-ha how true. This was one of K/M bad machines, not as bad as the EP4300/4301 but still BAD! All OEM's have a flop every now and then, unless of course you are Panasonic then all your machines were flops!
        • Gab
          • Aug 2015
          • 671
          #19
          Re: biz 501
          Does anybody know if there is a reseter tool or software for biz 501 ?
          As i have told you i need to clear CE password . I don' care about counters or anything else.
            Re: biz 501
            you missed the post about resetting counters... from the sounds of it you DO need to worry about counters
            • Gab
              • Aug 2015
              • 671
              #21
              Re: biz 501
              You mean by "to worry about counters" to use then during service to get informations about machines history or that they cause problems.
              If it the first i don't mind about counters because i plan to replace this machine in close future but not now.
              If by resetting nv ram, CE password cleared then how can i reset it?
                Re: biz 501
                resetting counters on some units will put the settings back to NEW CONSUMABLE status.
                IF the parts are OLD/USED you will cause quality problems.
